Clutch Slave cylinder replacement
Old Mar 16, 2017 | 09:48 AM
  #46
ZSpeedPerformance's Avatar
ZSpeedPerformance
Originally Posted by Jonesmeister11
Nice!
My buddy just picked up a 2011 c63 black series and that things light flywheels makes the rev counter so sexy. How fast it jumps and dives. Ugh.
Got the car back from the dealer today. Here is what my current clutch fluid looks like. This is after about a year with the new CSC. You can see black bits floating around in there.
With an Internal CSC the fluid will always get dirty, The CSC will collect clutch dust on the sealing surface of the slave, Once it is actuated the clutch dust will smear on the inner tube of the sealing area, The fluid will clean it back off but will get in the fluid when it does, It then floats to the top of the system (reservoir) It's not something to really worry too much about but we do recommend flushing it about 2 times a year to prevent it from getting too dirty.
Old May 9, 2019 | 12:50 PM
  #47
teahead's Avatar
teahead
Stupid question, but what are the symptoms of a bad CMC? CSC? How do you differentiate which one is bad?
Old May 9, 2019 | 01:34 PM
  #48
ZSpeedPerformance
CSC Slave Cylinder will leak fluid and your fluid level will drop and no pedal.
If it is just the Clutch Master Cylinder you will not normally lose fluid but will not have a full pedal or no pedal at all.
Normally master goes bad from contaminated fluid. Really is best to replace both at the same time.
