Clutch Slave cylinder replacement
Old Feb 17, 2017 | 01:02 AM
  #31
Jonesmeister11's Avatar
Jonesmeister11
Oh jeez after reading all these posts I think I might be screwed again. I purchased the Z speed HD CSC and had my clutch fluid replaced with GTR blue brake fluid. Well within a few months it turned brown again and I have black floaties just like I had when my CSC failed.
Keep us updated on how your work comes out.
Old Feb 17, 2017 | 03:28 PM
  #32
canucklehead's Avatar
canucklehead
^ did you replace the MC along with the CSC and fluid flush? if not, the service manual recommends this in bold. otherwise contaminants from one part can make their way into the new part and lead to failure.
Old Feb 17, 2017 | 10:46 PM
  #33
Jonesmeister11
I'd have to look at the service history, but I think so.
Old Feb 19, 2017 | 07:40 AM
  #34
Mercerb's Avatar
Mercerb
yep, if you are putting an aftermarket kit on with an OEM CSC, youll be pulling it back out in a couple months
Old Feb 21, 2017 | 06:04 PM
  #35
AlvaroJCeballos's Avatar
AlvaroJCeballos
I ordered the stage 1 quiet clutch kit with the CMAK kit from Zspeed and got it installed this past weekend. The car drives amazing. The only issue my mechanic had was with removing the old master cylinder. Luckily he figured it all out. I hope to not have an issue with clutch anytime soon. Thank you all for your replies!
Old Feb 21, 2017 | 07:17 PM
  #36
saywat?'s Avatar
saywat?
u should take a look around the mc area make sure they didnt break anything while trying to get it out. its a bitch.
Old Feb 21, 2017 | 11:17 PM
  #37
AlvaroJCeballos
They said that they had to unbolt the clutch pedal and some other stuff to be able to get it out. I will take a look tomorrow to see if I find something out of place or damaged.
Old Feb 22, 2017 | 12:27 AM
  #38
saywat?'s Avatar
saywat?
I'd check there n around the mc
Old Feb 25, 2017 | 08:21 AM
  #39
Sig6MT's Avatar
Sig6MT
Can you share more about this kit? I find the clutch on my 2013 6MT Difficult to shift smooth (without jerking)
What prompted you to do add this kit
Can you describe in more tangible manner what the difference you noticed?
Did you have to replaced the MC or clutch fluid?
Thank you
Old Feb 25, 2017 | 03:50 PM
  #40
AlvaroJCeballos
This is the kit I purchased ZSpeed Performance Nissan Infinti OEM & Performance Parts
I too was having issues shifting he car smoothly before the MC gave out. When the mechanic took everything apart, he noticed that the MC was the one that allowed all of the clutc fluid to leak out. He also noticed that the slave cylinder was on its way out too.
The flywheel also had some weird movement to it, not really sure how to describe it.
I decided to replace the MC, Slave cylinder, clutch flywheel and the transmission fluid all at once. The car drives so smoothly now. Now jerkiness when shifting through the gears.
I basically just got the mechanic to install the whole kit above. I also ordered the clutch fluid along with it, and I picked up some transmission fluid from Nissan.
The only thing that could potentially be bothersome for someone, is the tiny rattle that arises when slightly accelerating at a low RPM; most likely due to the flywheel being single mass as opposed to dual mass. I'm really pleased with the kit.
I was originally going to purchase the stock replacement clutch kit, but I decided to go with the stage 1 instead.
Old Feb 25, 2017 | 10:17 PM
  #41
Jonesmeister11
How many lbs is the flywheel you installed?
Old Feb 26, 2017 | 12:21 AM
  #42
AlvaroJCeballos
It's 26lbs! There were lighter flywheels available, but I wasn't looking to spend more money on a lighter, more expensive one.
Old Feb 28, 2017 | 06:49 PM
  #43
Jonesmeister11
Nice!
My buddy just picked up a 2011 c63 black series and that things light flywheels makes the rev counter so sexy. How fast it jumps and dives. Ugh.
Got the car back from the dealer today. Here is what my current clutch fluid looks like. This is after about a year with the new CSC. You can see black bits floating around in there.
Old Mar 1, 2017 | 09:51 AM
  #44
sLADe781's Avatar
sLADe781
Wow, definitely flush that fluid out before it contaminates the rest of the system.
Old Mar 1, 2017 | 11:18 AM
  #45
Jonesmeister11
Not a bad idea, but it's probably too late. It's been like this for almost year. But probably still a good idea to prevent further damage, and too see if more particles emerge.
