Clutch Replacement
Old Jan 31, 2017 | 08:32 PM
lilchrisg's Avatar
lilchrisg
Clutch Replacement
Question, I need to replace my clutch for my G37 sport. If I do so will that also correct my light grinding sound shifting into 4th gear? If not, how can I correct that? Haven't been able to get a clear answer.
Old Jan 31, 2017 | 10:02 PM
xnick101's Avatar
xnick101
No. I fixed my grind going into fifth gear by changing the trans fluid. If that doesn't fix it then you need to rebuild your syncro.
