Running Lean
Old Dec 16, 2016 | 06:24 PM
SonicVQ's Avatar
SonicVQ
Originally Posted by Ape Factory
I did not know that! I'll have to check my a/f tomorrow. I did verify the readings on a dyno with their wideband and it had the same readings as my bluetooth OBD dongle through Fusion. I can't get my sample rate as high as I'd like (about four samples a second). But I can still see the trend and interpolate.
We should start our own thread... (I did: https://www.myg37.com/forums/engine-...ml#post4096783)
I have have 5 different obd dongles and the sample rates range from 12 - 28 per second, but I use wi-fi, not bluetooth.
Are you iOS or Android?
(My apologies to the original thread starter, I didn't mean to derail your thread)
Old Dec 17, 2016 | 11:22 AM
Ricio1991's Avatar
Ricio1991
No worried its related to the subject lol I'm getting my car checked right now to see what could be causing the issue
Old Dec 17, 2016 | 12:18 PM
Ricio1991's Avatar
Ricio1991
Confirmed that there are no leaks in my exhaust system. I'm taking it to infiniti Thursday I hope they don't blame it on the mods. They're already saying it might be the intakes when I had my Stillen Gen 3 for about 6 months now will see the outcome lol
Old Dec 20, 2016 | 11:05 PM
Ape Factory's Avatar
Ape Factory
My bone stock G37 has similar AFR when the ambient temps are high. The rich mixture is used to cool the combustion chamber to prevent detonation.
On a cool day they are mid 12s at WOT.
You were right. I did a short run tonight on the way home and I hit low 11's at redline. The air/fuel ratio worked it's way from mid 12's to low 11's. Still room for improvement.
Old Dec 22, 2016 | 11:07 AM
Acrylic's Avatar
Acrylic
I just got my Injen CAI installed last weekend with High flow cats & my CEL is on as well. After reading this thread I'm going to check to make sure my car isn't running lean and if everything is running smoothly.
Old Dec 22, 2016 | 03:36 PM
Ricio1991's Avatar
Ricio1991
My cel went off on its own. So weird it's seems fine now not too sure if it'll come back so I'm not taking it to the dealer until it comes back on
Old Dec 30, 2016 | 02:11 PM
Kris9884's Avatar
Kris9884
If you don't plan on doing any major power adders, I'd say its tune time with what mods you have.
Old Dec 30, 2016 | 06:49 PM
Ricio1991's Avatar
Ricio1991
Yeah that's the plan I have to save up
Old Jan 21, 2017 | 12:40 PM
Ricio1991's Avatar
Ricio1991
Found the problem😐
It's unconnected
Old Jan 26, 2017 | 11:02 PM
SonicVQ's Avatar
SonicVQ
Found the problem😐
It's unconnected
What exactly was unconnected? I am assuming one of the PCV hoses.
