Red Oil light
Old Dec 5, 2016 | 03:51 AM
Louiegee97's Avatar
Louiegee97
Red Oil light
So ive noticed sometimes when i stop at a red light and the car is idling it drops rpms under like 600, the engine shakes for a about 2-3 seconds and the red oil light comes on. I dont think thats normal.. can anyone please let me know whats wrong?
Old Dec 5, 2016 | 07:48 AM
arkangyl's Avatar
arkangyl
Mega low on oil, maybe worse, stop driving and check your oil levels (and probably add more - 5W-30)
At a stop the engine slows down the most, which in turn creates the lowest oil pressure and will highlight a low level.
Do a full oil change and look for any metal shavings in the old oil - this would indicate preliminary motor failure
I'd highly suggest taking it to a mechanic for a full check
Old Dec 5, 2016 | 08:18 AM
Did you just recently buy the car? If not, when was the last time the oil was changed? This car takes 5.2 qts of oil, I'm guessing you're at about 3 qts. Hopefully a fresh oil change will take care of this, but like arkangyl suggested, you should get this checked out as being that low on oil is rarely without a problem w/ the motor or it's seals. G/L
Old Dec 5, 2016 | 07:55 PM
Louiegee97's Avatar
Louiegee97
I bought the car in march, i change the oil myself every 3 months or 3500 miles. I only use Mobil 1 Full synthetic 5w-30 with a K&N filter, but yes im taking it to a mechanic ASAP thanks guys.
Old Dec 5, 2016 | 08:44 PM
Hopefully it's something simple like a faulty sensor. Keep us posted on what you find out. G/L
Old Dec 5, 2016 | 11:19 PM
si_driver's Avatar
si_driver
Hey it's your money, but why would you want to change your oil every 3500 miles with full sync oil?
Even with regular oil you can easily go over 5,000 miles.
When I got my G35 in 2002, I have been sending my oil samples to Blackstone Labs for analysis. Even at 7,500 miles the oil was is great condition. Blackstone even suggested to increase the 10,000 which I have done.
Car now has almost 257,000 miles with zero issues and still runs like the first day I bought it.
but to answer you specific question:
If the oil isn't really low, make sure to check the oil pressure. It could that damn gasket issues that some are experiencing.
Old Dec 6, 2016 | 08:13 PM
petemo94's Avatar
petemo94
So when the RPMs drop below 600, the oil pressure is low enough to kick on the oil light. This is what happened on your car and most cars that fall under a certain RPM range. I noticed it while learning to drive a manual transmission car.
What you need to understand is how to address the low-idle condition that creates this. Dirty plugs, dirty intake, PCV valves clogged, fuel pressure, fuel filter (not sure if one exists), could all contribute to a low idle condition. I dont think our cars have ICV's (idle control valve) due to the VVEL and throttle design. If it did, the ICV on some cars does get clogged that creates a similar condition.
So I would research the idle dipping first and not worry as much about the red light (even though RED = bad). GL wth it.
Old Apr 29, 2018 | 10:22 AM
NOBOX7's Avatar
NOBOX7
this is your problem bro
Old Apr 29, 2018 | 07:03 PM
takemorepills's Avatar
takemorepills
Originally Posted by NOBOX7
Old thread! But, when I saw it come up, I knew it is exactly what you posted. This is why I limited my G coupe search to 2012+, supposedly they get the upgraded to a metal gasket(s).
