Neeed Helppp Clutch & Flywheel Replaced i get no gears???!!!
Old Aug 27, 2016 | 09:39 AM
23briann's Avatar
23briann
Unhappy Neeed Helppp Clutch & Flywheel Replaced i get no gears???!!!
I have a g37s 2008 just recently swapped out the transmisssion 6mt at 83k miles got new flywheeel & clutch by SPEC Stage 3 but i cant seem to get in gear seems like the flywheeel is a lil more bigger than the clutch disk I NEED HELPP!!!!
Old Aug 27, 2016 | 11:36 AM
sharkey's Avatar
sharkey
I had this problem when i bought a spec clutch and fidanza flywheel for another car....
Im assuming you have oil in the tranny?
But to the good stuff, the throw out bearing wouldnt touch the pressure plate fingers even though it was made for the car.
Also im assuming you replaced the throwout bearing?
Old Aug 27, 2016 | 11:38 AM
sharkey's Avatar
sharkey
Also... you bled the slave cylinder?
Why did you replace the tranny at 83k miles?
Old Aug 27, 2016 | 03:19 PM
23briann's Avatar
23briann
I replaced the throwout bearing & the pilot bearing & csc is replaced & i had replaced it because the old owner would abuse the gears 5th gear was grinding badd
TommyGunnZ33
17
Aug 24, 2022 10:50 PM
g37rolls
Jun 25, 2016 08:39 PM
Gfactor_416
Apr 20, 2016 05:26 PM
