Disabling VDC
Old Jun 8, 2016 | 11:16 AM
jgronline's Avatar
jgronline
Disabling VDC
- Stock G37s Sedan with IPL wheels
- VDC "disabled" by pushing the VDC button
- Stability control still kicks in and robs power
- Best solution I've found is to unplug the Yaw sensor just behind the gear shift so VDC is always disabled.
Old Jun 17, 2016 | 09:00 AM
hobbs's Avatar
hobbs
Coming soon; I crashed my stock G37s sedan.
Old Jun 17, 2016 | 09:45 AM
astat4's Avatar
astat4
Make switch to the sensor instead of disconnecting it.. you might want it in the rain
Old Jun 20, 2016 | 12:49 PM
jgronline's Avatar
jgronline
So all of those other cars I've driven for hundreds of thousands of miles without this "feature" and never had a problem was some sort of miracle? Please.
Old Jun 28, 2016 | 05:22 PM
ANMVQ's Avatar
ANMVQ
you can shut this off with ECUTEK
Old Jun 29, 2016 | 01:32 PM
Overboard's Avatar
Overboard
ICYMI: That light also comes on because the G uses the same system to make your open diff simulate limited-slip behavior through your traction control system. It's not robbing you of power, it's applying the brake to the wheel that's slipping. Do as you wish, but I'd never ever disable the yaw control. It's saved my bacon more than once.
Gregor12
Jun 22, 2016 10:08 AM
g37nightrider
May 23, 2016 01:15 AM
Allboutcali
Apr 4, 2016 04:48 AM
Ozzie069
Mar 29, 2016 07:44 AM
chee37
Mar 24, 2016 04:34 PM
