Trying to understand the "Throttle Lag" issue
Old May 15, 2016 | 03:03 PM
SonicVQ's Avatar
SonicVQ
Is the throttle lag issue only for certain years of production, 5AT, 7AT or 6MT?
Old May 15, 2016 | 03:17 PM
jomama22's Avatar
jomama22
I think it has to do more with how the ECU driver profile was made durring calibration and the type of driving you're doing at any given moment. I notice much more lag when I'm cruising or in slow traffic then if I am on the back roads acceleration hard and breaking hard. It also seems to put itself into a much quicker reacting profile after I break 90 or 100 mph in an aggressive fasion.
Doing a reset and then driving aggressive afterwards does help some but only so much.
This is with a 2012 7at RWD S model
Old May 15, 2016 | 04:25 PM
It seems to be most prevalent in the 09+ 7AT equipped Gs, the transmission shifiting logic has undergone several updates to try and help w/ this issue and has gotten better w/ each update. I believe the current AT Q50s seem to have the best behaved ATs, maybe they'll eventually apply that recipe to our ATs but I wouldn't hold your breath.
I had an 07 5AT that didn't have much lag, I think the extra 2 gears seems to have caused a more complex logic and at times it seems the transmission hesitates between shift choices whereas the 5AT has simpler mechanics.
Just my 2cs.
Old May 15, 2016 | 04:58 PM
G37sGraphite's Avatar
G37sGraphite
7 AT primarily from my research. Reset, traction control off, driving in DS, throttle controller....plus driving like a mad man helped my car. This car also does not like when you floor it, it tends to hesitate worst when that occurs. The the smooth, quick but progressive/gradual application of the throttle pedal instead of flooring it reduces the lag also.
Just my 1 cent...
Old May 15, 2016 | 09:09 PM
SonicVQ's Avatar
SonicVQ
Do I have this right... It seems to be a transmission issue (not shifting down) and not really a throttle response issue?
Old May 15, 2016 | 10:45 PM
IMO that would be accurate, the transmission gets in an indecisive "holding pattern" rather than a quick shift. Like I mentioned it seems to have gotten better w/ each update, I don't experience this too often, and it takes some adaptation on the driver as well.
I think I've adapted for the most part, lol.
Old May 17, 2016 | 07:09 PM
twin_snails's Avatar
twin_snails
Also a tune will take car of the throttle lag and clean up the shifting on the 7AT.
Old May 19, 2016 | 02:54 PM
MistahGuy's Avatar
MistahGuy
Just my 1 cent...
I have noticed this as well.. A quick flooring seems to completely retard the throttle for me and then jolt me forward. QUITE unpleasant, but the steady press down accelerates/shifts fine.
TurkeyDirk
ECU Tuning / Dyno Data
Apr 18, 2017 04:46 PM
Site Feedback & Suggestions
May 21, 2016 05:21 PM
Infiniti7
May 13, 2016 07:17 AM
towerworld
May 10, 2016 02:31 AM
msonbolg37x
Apr 20, 2016 08:29 PM
