Help Engine shakes when the A/C is OFF !!
Old May 9, 2016 | 09:44 PM
  #61
DevilsG37s's Avatar
DevilsG37s
Originally Posted by Rr1982
And it accelerates smoothly
Yes. Even when it was bad before cleaning the plugs.
The issue only when idling up to 2.5k rpm or so with no a/c.
Old May 9, 2016 | 10:05 PM
  #62
Rr1982's Avatar
Rr1982
Originally Posted by DevilsG37s
Well, SonicVQ..you're the man
It's clearly the 6th Cylinder is misfiring like hell. Here are the logs:
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 65.535V Min: 0.4V
Test result value: 2.14V
PASS
MID:$01 TID:$84
Max: 4.399V Min: 0V
PASS
MID:$01 TID:$85
Max: 2.149V Min: 0V
Test result value: 2.07V
PASS
MID:$01 TID:$86
Max: 65.535V Min: 2.25V
Test result value: 5.065V
PASS
MID:$01 TID:$87
Max: 65.535 Min: 0.3
Test result value: 0.558
PASS
MID:$01 TID:$88
Test result value: 0.48
PASS
MID:$01 TID:$89
Max: 0.449 Min: -32.768
Test result value: -0.04
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.17V Min: 0V
Test result value: 0.17V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 2.55V Min: 0.7V
Test result value: 0.7V
PASS
MID:$02 TID:$80
Max: 1.19V Min: 0V
Test result value: 0.2V
PASS
MID:$02 TID:$81
Max: 2.55V Min: 0.48V
Test result value: 0.6V
PASS
MID:$02 TID:$82
Max: 3.9S Min: 0S
Test result value: 0.4S
PASS
MID:$05 TID:$83
- O2 Bank 2 Sensor 1
Test result value: 2.085V
PASS
MID:$05 TID:$84
Max: 4.399V Min: 0V
PASS
MID:$05 TID:$85
Max: 2.149V Min: 0V
Test result value: 2.04V
PASS
MID:$05 TID:$86
PASS
MID:$05 TID:$87
Test result value: 0.694
PASS
MID:$05 TID:$88
Test result value: 0.594
PASS
MID:$05 TID:$89
PASS
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Max: 0.17V Min: 0V
Test result value: 0.16V
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$80
Max: 1.19V Min: 0V
Test result value: 0.67V
PASS
MID:$06 TID:$81
Test result value: 0.48V
PASS
MID:$06 TID:$82
Max: 3.9S Min: 0S
Test result value: 2.3S
PASS
MID:$21 TID:$80
- Catalyst Monitor Bank 1
Test incomplete or dependant test failed
MID:$21 TID:$82
MID:$22 TID:$80
- Catalyst Monitor Bank 2
MID:$22 TID:$82
MID:$35 TID:$80
Max: 13° Min: -13°
Test result value: 2.5°
PASS
MID:$35 TID:$82
Max: 13° Min: -13°
Test result value: 1°
PASS
MID:$35 TID:$84
Max: 499ms Min: 0ms
Test result value: 109ms
PASS
MID:$35 TID:$85
Max: 10,779ms Min: 0ms
Test result value: 10ms
PASS
MID:$36 TID:$80
Max: 13° Min: -13°
Test result value: 4.5°
PASS
MID:$36 TID:$82
Max: 13° Min: -13°
Test result value: 0°
PASS
MID:$36 TID:$84
Max: 499ms Min: 0ms
Test result value: 107ms
PASS
MID:$36 TID:$85
Max: 2,379ms Min: 0ms
Test result value: 20ms
PASS
MID:$3c TID:$81
- EVAP Monitor (0.040")
Max: 32.767kPa Min: 0.43kPa
Test result value: 32.767kPa
PASS
MID:$3c TID:$82
Max: 32.767kPa Min: 0.1kPa
PASS
MID:$3d TID:$83
- EVAP Monitor (0.020")
Max: 655.34998V Min: 0.02V
Test result value: 0.03V
PASS
MID:$41 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 4.779V Min: 0.39V
Test result value: 1.205V
PASS
MID:$42 TID:$80
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 4.71V Min: 0.24V
Test result value: 1.58V
PASS
MID:$45 TID:$81
- O2 Heater Monitor Bank 2 - Sensor 1
Test result value: 1.195V
PASS
MID:$46 TID:$80
- O2 Heater Monitor Bank 2 - Sensor 2
Test result value: 1.44V
PASS
MID:$81 TID:$80
- Fuel System Monitor Bank 1
MID:$81 TID:$81
MID:$82 TID:$80
- Fuel System Monitor Bank 2
MID:$82 TID:$81
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 2Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 1Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
Test result value: 3Count
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
Test result value: 15Count
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
Test result value: 213Count
PASS
End of report.
I just read all of your status reports and have not seen one cylinder 6 misfire they all say pass. Also we do not have wideband OEM O2 sensors. I would suggest pulling your bank 2 O2 sensors and cleaning them with mass air flow cleaner wiping them off really well. Have you looked at your tailpipe when the car is idling and when you throttle up at a dead stop have someone staying back there or have someone put your throttle pedal and see how much black smoke blows out of both pipes or one pipe that would cause a bad idle and have a less noticable effect on acceleration.
Old May 9, 2016 | 10:14 PM
  #63
DevilsG37s's Avatar
DevilsG37s
Yup it says pass but you can see the counts number only in current cycle was 215.
As for OEM sensors, check this out:
https://www.myg37.com/forums/audio-v...ed-temp-5.html
That's likely what I'm going to do. I'm even thinking of repacing the o2 sensors with new ones.
Old May 9, 2016 | 10:26 PM
  #64
Rr1982's Avatar
Rr1982
Narrow band reads 0 - 1 volt and a wideband reads 0 to 5 volts that post that you link is misinformation and misunderstanding by the poster
Old May 9, 2016 | 10:32 PM
  #65
DevilsG37s's Avatar
DevilsG37s
Then no, I don't have a wideband sensor. But may I ask what would you want to know if there is a wideband one?
I can get you the AFR while idling, cruising and when in WOT very accurately.
Old May 9, 2016 | 10:40 PM
  #66
Rr1982's Avatar
Rr1982
Well I'll tell you.idle should around 14.0-14.7.cruise AFR around 14.0-14.5 AFR wide open throttle around 12.5-13.0 AFR on an NA car.
  #67
Rr1982's Avatar
Rr1982
If you pull that O2 sensor in it looks anything like some of those plugs then I would say you definitely have a contaminated O2 sensor which could be causing a problem and it could be because of the STP
Old May 9, 2016 | 10:42 PM
  #68
Rr1982's Avatar
Rr1982
But honestly if 40000 miles it shouldn't need O2 sensors
Old May 9, 2016 | 10:47 PM
  #69
DevilsG37s's Avatar
DevilsG37s
I'll try and inspect the sensor when I have some free time.
40k miles with no STP **** then you're right lol.
Hopefully some sensor cleaning and everything would be great again.
Thanks man
Old May 9, 2016 | 11:03 PM
  #70
Rr1982's Avatar
Rr1982
Keep us posted. Good luck
Old May 10, 2016 | 03:03 AM
  #71
Rr1982's Avatar
Rr1982
Use some aerokroil to loosen those.
Old May 10, 2016 | 04:27 AM
  #72
DevilsG37s's Avatar
DevilsG37s
Actually I know a buddy of mine that has a shop which installed many exhaust and has Oxy Acetylene Torch which can loosen up the sensors pretty easily.
Will contact him for the next weekend to work on those sensors.
Old May 10, 2016 | 08:43 AM
  #73
Rr1982's Avatar
Rr1982
Check AFR at idle and look for rich exhaust first
Old May 11, 2016 | 12:20 PM
  #74
DevilsG37s's Avatar
DevilsG37s
Checked, Idling at 14.6~
Also checked when putting high beams, still misfiring.
The thing is that after a couple days after cleaning the tbs and the plugs, all went well only for a couple days. Now the misfiring and the shaking is back only slightly less than before but very noticeable.
Made a test report and now it's cylinder #2 is the one that is misfiring non stop.
I guess my O2 sensors are bad so I ordered a couple from rockauto "denso"
Will first clean injectors by an injector cleaning machine. After that change the plugs and the sensors all together.
Will report back after.
jk315
Intake and Exhaust
Apr 6, 2016 11:45 AM
jhovanyrod
Jul 10, 2015 02:02 AM
twin_snails
13
Oct 21, 2012 06:23 AM
snaik69
Intake and Exhaust
21
Jul 24, 2012 01:00 PM
mikelebron
Intake and Exhaust
Oct 14, 2011 03:48 AM
