Does this part fix spark plug tube oil leak?
Old Apr 19, 2016 | 12:52 AM
HTNut's Avatar
HTNut
My 2008 coupe has the #6 spark plug tube oil leak, so I ordered new valve cover seals, and what is called the 'inner valve cover seal' (see attached). For anyone who has replaced the valve cover seals, did you replace the inner seal also? Will this fix the oil leak?
Attached Thumbnails Does this part fix spark plug tube oil leak?-inner-valve-cover-seal.jpg
Old Apr 19, 2016 | 06:01 PM
SonicVQ's Avatar
SonicVQ
Yes, that is the one!
One caution:
Do not over tighten the valve cover bolts and make sure to tighten in the proper sequence and in two steps:
1st step: 2.0 N·m (0.2 kg-m, 18 in-lb)
2nd step: 8.3 N·m (0.85 kg-m, 73 in-lb)
If you haven't done so already, check the factory shop manual under "IGNITION COIL, SPARK PLUG AND ROCKER COVER" for further details.
Good luck!
Old Apr 20, 2016 | 03:06 AM
HTNut's Avatar
HTNut
Thanks SonicVQ! I got a 1/4" drive torque wrench for this job, hope to get it done this weekend.
4DRZ
Motorsports / Track
17
Jun 17, 2016 03:03 PM
m3clubracer
Apr 20, 2016 09:14 PM
Kris9884
General Tech Questions
Apr 20, 2016 09:08 AM
ALbert Cui
Northern California
Apr 15, 2016 10:49 PM
JohnsG37x
Apr 15, 2016 03:45 PM
