g37 twin turbo gear problem help
Old Mar 11, 2016 | 11:14 AM
abodrc's Avatar
abodrc
I have g37 2008 stage one gtm with transgo valve body 5 speed every thing was run good
I stop for five minutes when i put the gear in R car dosent move after that the gear dosnt work even R or D the car only revving and when i turn the car off and start it again i put the gear on D it move only few meters after that on revving
It the problem in clutch? ? Help? ?
And sorry for my bad english
Old Mar 18, 2016 | 04:14 PM
SonicVQ's Avatar
SonicVQ
Check the automatic transmission fluid level. Also, look at the colour (should be a nice bright red, not a dark red or brown) and see how it smells. Does it smell burnt?
If the fluid checks out, more than likely you will need to take it to a shop to get an estimate.
Old Mar 18, 2016 | 04:19 PM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Agreed with the transmission fluid. Maybe time for a fluid flush. If you are pushing significant power (whp) it may be a tune issue that is causing the torque converter to lock up wrong and degrading your clutch packs.
Old Mar 18, 2016 | 04:40 PM
abodrc's Avatar
abodrc
Thanks i check the oil level there was less but there was other problem i take the car to garage to check it this week
But i dont know if the 5at can handle ... the car near 500whp the gear only have cooler and transgo vavlebody ?
Old Mar 18, 2016 | 04:44 PM
abodrc's Avatar
abodrc
Thankyou
I will check that but what i want to know if the 5at can handle ... the car near 500whp the gear only have cooler and transgo vavlebody is that enough for daily drive and few race ?
RussianGiraffe
Mar 8, 2016 08:09 AM
2009IPG37S
Mar 6, 2016 07:29 AM
the_wolff
Mar 6, 2016 07:21 AM
Xenolith666
Mar 5, 2016 06:04 PM
