0-60 vids comparing drive modes
Hello there. Just bored so I decided to post up a comparison between D and DS DRIVE modes in 0-60 mph scenarios.
This car is completely bone stock besides R2C intakes. I do not have a tune. Thankfully my old lady 08' G is holding up nicely
I tried to keep the environment and all elements as consistent between the two runs as possible so I stuck to using the same road and to avoid any heat soak, runs were done within 15 minutes of each other on the same night.
here is 0-60 in D
here is 0-60 in DS
all in all, really don't know if there is any NOTICEABLE difference in regards to shift times between the two modes in straight line scenarios.
here is 0-60 in D
here is 0-60 in DS
Thanks for posting that...
DS vs D primarily changes shift characteristics mostly noticeable at part throttle. At full throttle they are both going to act the same (although you got a little slippage on the second run).
0-60 is so subjective....quarter mile might be more telling although I believe that WOT they will probably be equal. However, around town when your driving 99% of the time and short sprints from stop light to stop light the DS mode is a noticeably more responsive. As KAHBOOM mentioned it is mostly noticeable at part throttle....
Coming from a Corvette I hate the D mode...DS is much better...
Feffman
Midwestern
Mar 19, 2016 07:31 PM
