door seal (weather stripping)
Old Nov 24, 2015 | 09:32 PM
mcola's Avatar
mcola
Hi all, any help would be appreciated.
On several occasions I have tried reseating the rear door seal on my 2012 sedan. Its the one that attaches to the upper chrome area of the door which seals against the upper jamb of the car body. There is one spot that continually works itself loose which I wonder is because I don't fully/properly reseat it each time I try to. The seal isn't damaged or stretched, and it would seem easy enough to take care of but I must be missing something.
Thanks in advance.
Old Nov 24, 2015 | 09:39 PM
Thanks in advance.
Had the same issue on our 07 but not on our 09. Tried time & again to get it to seat properly, seemed like it was good and just kept popping loose in that one area. The dealer was able to make it right since it was under warranty, might just take it in and see what they say, otherwise it may drive you crazy.
Old Nov 25, 2015 | 06:35 PM
mcola's Avatar
mcola
The dealer is certainly an option. Talking to a couple friends about this, I got the idea of using either a few dabs of silicone or double sided tape at the base of the seal so it won't dislodge as easy. It wouldn't surprise me if this is all the dealer would do.
Old Nov 25, 2015 | 09:03 PM
socketz67's Avatar
socketz67
Community Builder
If I understand correctly, this was the same issue I had on my 04 and 13. To fix, i wait for it to get warm, push it into place, and then I stretch/push the entire seal away from where it normally pops loose. Down, then to the side, away from the problem area. The delaer actually showed me how to do this long ago, and I now check them every week when I wash/dry the car.
Old Nov 25, 2015 | 09:49 PM
mcola's Avatar
mcola
Thanks for the info, I'll have to give that a try.
Old Dec 5, 2015 | 12:32 PM
mcola's Avatar
mcola
That seems to be the trick, and is working so far. Thanks!
Old Dec 6, 2015 | 10:32 AM
socketz67's Avatar
socketz67
Community Builder
Excellent news.
JM Auto Racing
Supporting Vendors
Apr 12, 2016 04:40 PM
main_shoby
Nov 24, 2015 09:59 PM
OfficialG
Nov 23, 2015 11:42 PM
mezzo
Nov 22, 2015 07:18 PM
lil_dave
Nov 21, 2015 07:40 PM
