Ugh another failed Slave Cylender
Old Dec 12, 2015 | 02:09 PM
telcoman's Avatar
telcoman
Originally Posted by Jonesmeister11
Well I guess it was time. Was taking my girl friend home and noticed I was having more clutch issues than normal, .......... It may be in my head but I swear I was having some mild clutch slippage before I got to my girl friends house.
Thanks guys,
Austin
Is it fair to assume there was no happy ending that evening?
Telcoman
Old Dec 13, 2015 | 01:35 AM
JSolo's Avatar
JSolo
Just say no!!!!!
To the OP, what year is the car? What actual warranty remain on the car? Why would they cover the MC under warranty and not the CSC?
Old Dec 13, 2015 | 01:53 PM
Jonesmeister11's Avatar
Jonesmeister11
2011
No factory warranty, all state's aftermarket warranty.
The issues is, the clutch had debris from the hose go through the clutch fluid system, causing the CSC to fail. The dealer says they need to flush the system, replace the mc, CSC, and tube (whatever that is). If they ask the warranty company to repair all of this, the company will send an inspector out. The warranty company see that they only need to replace the failed part (CSC). The dealer, and any members, said you need to replace the mc as well, sort of a preventative maintenance.
Telcoman
I'm not one to kiss and tell
Old Dec 13, 2015 | 02:30 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I see. If I remember correctly, there's only two rubber hoses in the system, that's from the reservoir to the MC, the other is a small section by the trans/csc.
So depending which hose they're claiming failed (I'd love to know how they made this diagnosis), most of it should be covered under warranty. If they don't want to cover the MC/labor, fine, pay for it out of pocket. But they should cover everything else.
It clearly states in the FSM to never reuse the CSC or CSC tube (page 17 of cl.pdf for the 2012 sedan).
At 50K miles, it would probably be a good idea to replace the clutch anyways as you're getting free labor for 90% of the job. Pulling the pressure plate and clutch disk is minimal labor once the trans is off the engine. Also, depending on the length of your extended warranty, maybe even go with the heavy duty CSC as well.
Edit: I've never heard of a rubber hose failing like this. The clutch system is not that high pressure. If they determined this by black particles present in the reservoir, that's primary clutch disk wear particles. As I understand it, they contaminate the fluid at the CSC end and make their way through the system to end up in the reservoir. An important reason to flush the clutch line periodically (2 years?).
File Type: pdf
Old Dec 15, 2015 | 12:22 PM
Jonesmeister11
Agree 100% with everything you said. I assume they found particles in the fluid and assume it's the hose. I just got the HD CSC from zspeed in last night and running it to the dealer now.
So the warranty is paying for the mc and labor and I am having to pay for the HD CSC (obviously because aftermarket), and I think labor. I'm not happy about it, but I know with clutches warranty companies are already iffy.
Old Dec 22, 2015 | 05:39 PM
Tommy Gunz PSIU's Avatar
Tommy Gunz PSIU
Good call on the HD CSC. Did you choose to get a new clutch/flywheel as well? I had my Slave cylinder go out awhile ago and went with Southbend Stage 1 clutch and flywheel. I decided that since they were already in the trans i should have them get it done (i would highly recommend to save yourself some money in the future).
Old Dec 22, 2015 | 05:44 PM
User 122320's Avatar
User 122320
My car only had 2800.... Needed a new Slave, new CSC and according to my dash cam, a new Clutch.
Work order mentions nothing about a new clutch however. But the tech says, I put one in and it rides pretty smooth after he test drove it.
Old Dec 23, 2015 | 02:30 AM
Jonesmeister11
I had them check the clutch and flywheel. The tech said I had 70% life left on the clutch. Good to know since this is a preowned vehicle. I had planned on upgrading the clutch, but unfortunately I am taking a different route with the car. I just won't need a beefier clutch.
steez
12
Mar 8, 2016 01:45 PM
Baby Jumpman
Jan 27, 2016 02:40 PM
sho423
Dec 21, 2015 02:47 AM
Ayeetyy
Dec 6, 2015 11:06 PM
