Help transmission
Old Oct 21, 2015 | 06:10 PM
hooey_b's Avatar
hooey_b
transmission
so background story, I've had my 08 G37s 6mt since 2010...in 2012, i had galling on the synchro gear for 5th and 6th. the transmission was subsequently replaced, flywheel clutch and all at around 88k.
shifting is smooth and amazing, but two worries that are kinda on my mind:
1) whenever it's idling in neutral, i hear a chattering...i did research and read that it's usual for the vq37vhr to chatter a bit, but i just recently took it in for an alignment and the guy said it was my thrust bearing. any thoughts?
2) when i let off the gas in gear above 3k rpm, while the rpms are coasting down, around 3.3k-3.1k i get a...shuddering (there's no other way to put it) of the engine and i can feel it through the floor and through the shifter. it's not violent, but definitely noticeable....has anyone experienced any of this..?
Thanks!
Old Oct 22, 2015 | 01:38 AM
conkus805's Avatar
conkus805
concern 1 is normal, my 370 had that issue as well. issue 2 sounds like a driveshaft imbalance, your rear subframe mount may be bad. look for fluid on your rear diff, the rear mount is silicone filled and is known to fail. when it fails it leaks the silicone fluid all over your rear diff, this can cause vibration. whiteline makes a solid mount as a replacement that is very nice and won't fall like the stocker. good luck!
Old Oct 22, 2015 | 06:12 AM
hooey_b's Avatar
hooey_b
word, i was looking into replacing all my bushings here soon when i can find enough money lol. i need to do that and camber correction.
thanks!
soldier9599
Jun 16, 2020 02:04 PM
joey_v
Sep 6, 2011 06:12 PM
fasteddie
18
Jun 21, 2011 07:27 PM
makagr21
30
Jun 3, 2008 07:17 PM
