Roots/Twin Screw G37x
Old Oct 23, 2015 | 08:09 AM
ANMVQ's Avatar
ANMVQ
Originally Posted by PongSanity
I too wished that vortex made their own kit. Stillen air to water is straight thrash. Boosted performance custom air sc stillen kit still needs work but that's more so for the guys that already have the stillen kit and have a few thousand lying around to play with. Gtm/gamma can't get my money for there's.
In pertaining to this thread, my knowledge base isn't as vast as u or those commented but sub'd for progress. Might learn a thing or two.
Doesn't it sux there is NO SC option for us. I almost wanna get an 06 Just to have more options, LOL
Old Oct 23, 2015 | 03:01 PM
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by chuckie311
this cant be a direct bolt on as the lower piece bolts up to the lower manifold.. so unless you do some fab work like re-drill a few holes like you have to when you put the VQ37HR intake on..
You are correct, I was thinking of the Stillen kit which is made for the HR motors, but that kit uses a centrifugal type SC, so definitely not the same type of kit. Thanks for getting it straight for us!
Old Oct 23, 2015 | 03:12 PM
2GoRNot2G's Avatar
2GoRNot2G
I can tell you that I am VERY happy with my GTM SC kit with the Rotrex style supercharger on my VQ35HR. It's been in the car for 4-5 years now with no issues whatsoever (my car was the test car for the HR sedans). It idles perfectly and drives like it did from the factory when just cruising around town, but has a great power ban, especially when the RPM's start to hit 3000 and above (plus I can still get close to 30 mpg on the highway). The torque curve is also VERY flat which makes it really nice to drive around town. My Dad has the Vortech set-up in his 2005 Anniversary 350Z and not only does my G make more power, but it's more driveable and quite a bit quicker in a straight line, especially when doing a 60 - 100 MPH pull than his car. The unfortunate thing is GTM is no more and their kits are very hard to come by now.
Old Oct 23, 2015 | 04:37 PM
ANMVQ's Avatar
ANMVQ
Not dismissing their kit at all,. But post something we can actually buy . We "all" know how that went here and on the Z forum.
Yes the kit is great but not available unless its used and then GOOD luck if you ever need a part for it :/
Old Oct 23, 2015 | 08:56 PM
2GoRNot2G's Avatar
2GoRNot2G
^ FYI... I've heard of a few guys whom have gotten these kits from various GTM installers that still had them on the shelf (new) recently for a pretty decent price, so they may still be out there somewhere if you dig enough.
Old Oct 24, 2015 | 02:37 AM
PongSanity's Avatar
PongSanity
Yep! I had thoughts in building a '05 G35 Sedan just because the force induction options are so broad. On the g37 platform we got about 5 sc and turbo applications confined. It sucks.
Old Oct 26, 2015 | 03:04 AM
N2 THE ABYSS's Avatar
N2 THE ABYSS
Does anyone know offhand what the stroker engines are making while still N/A?
The more I think about this and start building my parts collection I'm left knowing that no matter how much power is made I WILL get bored, and I will end up taking it to the strip.
Therefore building the bottom end should be investigated further and all options.
So, to the title question,
When it comes to the Stroker kits I'd love to know what the gains are before boosting. The torque increase should be significant making the AWD G37 a beast off the line.
As for cost I'm ignoring that for now just to add to discussion and have a bit of, "if I could afford anything, what could I possibly do and what would be the outcome?" As I see it IF you're doing the bottom end (and not having to pay labor) at least try and do some upgrades other than just strengthening (if possible and worthwhile).
Theory and Hypothesis
The vq37vhr makes roughly 94.25chp per liter so using some very fuzzy math, going to 4.5l would net 424chp with no other mods and torque could go up a ridiculous amount. There would be a loss in RPM with could make the automatic trans go nuts.
With the added boost of the supercharger and now a built and larger bottom end let's just say 4.5l for estimate numbers, looking at the 500-600hp range (using a midrange boost pulley ((Lg pulley 7-8psi/M pulley 14-15psi/Sm pulley 28-30psi)) running 14-15psi on a 4.5l shouldn't be an issue to reach the goal.
The estimated numbers aren't including fine tuning and full exhaust upgrades. If we use a rough number of 10chp per PSI gaining 140-150chp isn't crazy especially when you add in the gains that the Water Meth Injection (WMI) will produce sprayed pre compressor. Spraying before the compressor (turbo and SC) increases the efficiency of the compressor substantially. Along with the added efficiency the WMI will raise the octane level from 93oct to 100-110oct making knock an almost non issue and possibly allowing for not having to lower timing at all on low to medium boost levels. The other obvious benefit is the cooling of the intake pre charger air making for a denser and less likely to detonate post charger air. It is also possible to run a leaner AFR, getting as close as possible to 12.5:1 or 13:1 while in boost will make for the best torque numbers.
Using Osiris software will allow for multiple tunes since WMI rely on something that can run out, having a tune with lowered timing and a richer AFR will keep things safe. Other tunes could vary in power greatly depending on if use of the WMI is fully taken advantage of or not.
Basically I'd expect to see (realistically) 500-575chp with 14psi and no other mods other than WMI and OSIRIS for tuning (essentially support) on a 4.5l engine.
Here's where the interesting thing comes in to play, I'd actually expect the 4.0l and 4.2l engines to put down nearly the same amount of CHP as the 4.5l since the RPM on the 4.5l would be drastically lower although the torque would be much higher on the 4.5l. The reason for this is "horsepower" is the amount of work you can do in a certain period of time and amount of work translates to torque. Therefore, Torque in a certain amount of Time = HP. With more RPM and less displacement you can make more HP and with Less RPM but more displacement you make more torque (think Honda VTEC engine vs a Diesel or big c.i. Gas V8).
This is where the use of the car comes into play when deciding which route to take. For a drag car we'd want high revs and with a daily we'd want more low/mid torque for stop and go. Meeting in the middle seems the best choice for a daily driver that will see the occasional pull here and there.
Another positive using a Supercharger over turbo's in the situation is the absence of lag and the linear delivery of power. Really any supercharged stroker setup being set for (higher) Torque or Horsepower will still be good on the street since torque delivery won't have any low spots while waiting for full boost.
**THIS POST IS BASED ON VERY ROUGH ESTIMATED NUMBERS JUST USED TO DEMONSTRATE THE DIFFERENCE IN SETUPS**
***If anyone has any, or can find any PRE-BOOST stroker dyno numbers I'd greatly appreciate it***
**Dyno numbers would also show the loss in RPM for the TQ gain on larger displacement**
*common stroker sizes and estimated peak output 4.2/395chp, 4.0/377chp*
**As I noted these numbers are just estimates based on liters divided by chp of the stock engine, torque numbers I didn't even bother because they will gain much more than hp numbers.
Old Oct 26, 2015 | 09:18 AM
ANMVQ's Avatar
ANMVQ
I dont think anyone has done just a NA build, ex: one guy but dont remember his name sorry, again, GTM did a stroker kit FI and made something like 800WHP. But their not a "real" option but at least its a number. NA build will cost you about 10k, I prices one out earlier this your and was getting a stroker(4.2) motor from importpartspro, Kyle s good people too! Vendor here.
Old Oct 26, 2015 | 09:22 AM
ANMVQ's Avatar
ANMVQ
Do you have pic of the SC you have? Just curious cause I have a extra upper plenum maybe I'll swing at this. :/
Old Oct 27, 2015 | 01:34 AM
PongSanity's Avatar
PongSanity
There's one guy who built his vq for most na purposes but he got like 360hp iirc. Most parts are from gtm.
Old Oct 27, 2015 | 05:48 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
yes he hit 371whp and 296 wtq
World Record NA VHR Build - Nissan 370Z Forum
Old Oct 27, 2015 | 05:59 PM
jwick's Avatar
jwick
Yes he did but he spent a lot more than one would to TT their car. Staying NA is just not a very cost effective option. Especially when you consider that you are going to have to live in the upper RPM ranges to see any of that power so it's not all that useable. Just boost it and be done
Old Oct 27, 2015 | 09:50 PM
chuckie311's Avatar
chuckie311
Depending on what platform your doing going boost can be expensive..upwards of 20k
Not everyone wants to go boosted and that includes me.. I'm happy where my car is at for the money I have spent on it..
Old Oct 31, 2015 | 07:50 PM
  #29
PongSanity's Avatar
PongSanity
Boost is addictive. There's always that little demon behind your ear telling you to crank the boost just 1 more psi.
Old Nov 17, 2015 | 12:33 AM
  #30
TheLocNar's Avatar
TheLocNar
I'd just wait for the 2016 Q50S Red.
ManDoo
Nov 11, 2015 08:18 AM
Rayramg37
Nov 5, 2015 12:54 PM
SON415
Oct 30, 2015 11:33 AM
adharamd
Oct 17, 2015 08:27 PM
