Another catch can thread
Old Jul 28, 2015 | 11:01 PM
TheLocNar's Avatar
TheLocNar
None of the others seemed to have gone anywhere (years old, not much info etc.).
So, I know some of you are running some catch cans. I've been thinking of this for awhile, as my car just passed 52k miles. Looks like I'll be holding onto it for awhile, and every little bit will help.
So, what have those with catch cans gone with? Assuming 2 are needed, unless there's a single one with all the fittings? Limited in knowledge about this, so go easy on me.
Old Jul 28, 2015 | 11:24 PM
PongSanity's Avatar
PongSanity
Arc catch can/coolant reservoir. Best one out. There's a chart out somewhere on here as to which hoses to tap into with the stock intake manifold. It's different if you have the m370 uim.
Old Jul 28, 2015 | 11:54 PM
TheLocNar's Avatar
TheLocNar
Arc for several hundred dollars. Nope. lol The eBay ones will do just as good.
Yeah been trying to find the chart. heh
Old Jul 29, 2015 | 11:23 AM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
I wish ARC would mass produce a little and lower cost. I'd spend some $$$ but the price is ridiculous.
Old Aug 5, 2015 | 05:00 PM
SlateBlue G's Avatar
SlateBlue G
These were pretty inexpensive.2 NRG cans. Only downside was I had to cut a small portion of the cover
Old Aug 6, 2015 | 08:17 AM
ANMVQ's Avatar
ANMVQ
Looks like an octopus LOL, Are you cans baffled?
Old Aug 6, 2015 | 02:26 PM
ToXIc's Avatar
ToXIc
is that where you hook them up? i though it was the little things that go into the intake tubes before the throttle bodies..
Old Aug 6, 2015 | 03:17 PM
ToXIc's Avatar
ToXIc
ok found this in another thread..
Originally Posted by Q8y_drifter
I still haven't connected the hoses actually. I ordered 3/8" hoses from Summit but they got lost in the mail so I'm working on that right now.
However, the installation is actually different on my car. On my G35 HR, there is a vacuum port (for PCV) that goes from the passenger side valve cover and connects to another port in the back of the plastic plenum.
For the VHR, you actually have two PCV vacuum ports, one on each valve cover, and each port is connected to another port at the front of the plastic plenum.
HR
VHR
For the VHR, you'll need to modify your catch can so that it has two ports for each, or you can get an ARC oil catch can/coolant reservoir combo tank that already has dual ports for the VHR.
so how to prevent oil getting into the throttle bodies?
Old Aug 6, 2015 | 03:35 PM
ToXIc's Avatar
ToXIc
more to add...
this makes more sense to me
Nissan 370Z Forum - View Single Post - Who's running a catch can?
from thread
Who's running a catch can? - Page 2 - Nissan 370Z Forum
Old Aug 6, 2015 | 03:53 PM
ToXIc's Avatar
ToXIc
also will most likely be using a compress air filter/separator instead of a Catch Can around the same cost if not way less and way more effective.
for e.g
McMaster-Carr
Old Aug 10, 2015 | 02:58 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
im going with 2 of these
Amazon.com: JEGS Performance Products 52205 Air Oil Separator: Automotive Amazon.com: JEGS Performance Products 52205 Air Oil Separator: Automotive
Old Aug 10, 2015 | 03:08 PM
i heart ricers's Avatar
i heart ricers
Originally Posted by chuckie311
http://www.the370z.com/diy-section-d...ors-cheap.html
http://www.newegg.com/Product/Produc...9SIA1RA11E1312
Old Aug 10, 2015 | 03:12 PM
chuckie311's Avatar
chuckie311
Originally Posted by i heart ricers
LOL you think 51 is a lot of $$$
I don't want to cheap catch can in my engine bay!
Old Aug 10, 2015 | 04:55 PM
ToXIc's Avatar
ToXIc
very similar to these
Shop Kobalt Mini Air Filter at Lowes.com
1/4 in. NPT Mini Air Filter-24343HOM - The Home Depot
Old Aug 11, 2015 | 08:15 AM
i heart ricers
and
Amazon.com: TEKTON 4755 Oil/Water Separator: Home Improvement Amazon.com: TEKTON 4755 Oil/Water Separator: Home Improvement
