Help Issue with throttle or automatic transmission?
Old Jun 25, 2015 | 01:03 PM
ohseedee's Avatar
ohseedee
I started having an issue a couple months ago and Infiniti has been no help. When in manual mode, my throttle cuts out when I hit a certain limit (low RPM). This is very similar to what would happen if I was red lining in a low gear and the throttle cut out to protect the engine. As you can see from the video below, I'm at about 3500 RPM and about 75 mph in 4th gear, and my throttle stops working and I start to slow down. I have gotten this to occur at 2nd and 3rd gear as well. If I up-sift I will get throttle response again. I don't feel like there is any reduction in engine performance. I don't think there is a problem when I'm in automatic mode. Please let me know if you have any ideas. I've had infiniti look at it and all they do is charge me for an inspection and say nothing is wrong. I want to go back with some specifc ideas of what it could be or if this is known.
2008 G37 coupe sport, manual 5 speed transmission
Old Jun 25, 2015 | 05:12 PM
ohseedee's Avatar
ohseedee
I'm going to try and post a better video in lower gears also. Please let me know if anyone has any thoughts. Thanks!
Old Jun 26, 2015 | 12:29 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Are you saying there's a dead spot at a certain position in the pedal or is it rpm related?
Old Jun 26, 2015 | 02:33 PM
ohseedee's Avatar
ohseedee
No. What is happening is certain gears will max out at certain low RPMs or low speeds (sometimes). For instance, some times when i go in manual mode and hit around 3500 RPM in 4th gear, the car disconnects the throttle. It feels just like if I was at red line in a low gear and the car disconnects the throttle to protect itself. Feels just like a speed governor kicking in. The only difference is i'm no where near red line or top speeds. This doesn't happen 100% of the time. I couldn't get it to happen this morning. But when it does occur I can repeat it every time during that same drive. I've seen it occur in 2nd, 3rd, and 4th gears. I dont think it is an issue with the throttle. I could be in auto mode and slam the peddle to the flour and and accelerate without problem.
Old Jul 24, 2015 | 08:02 PM
ohseedee's Avatar
ohseedee
My engine light finally came on and i'm not in limp mode. I can not take the car over about 2500 rpms. I read the error codes with a reader and I'm getting P0011 and P0524. I've googled what those codes are, but what does that mean? Is there anything I should try before taking it to the dealer and paying tons of $ to get it fixed.
redlinernyc
Feb 29, 2016 11:06 PM
xnick101
Intake and Exhaust
18
Sep 16, 2015 12:02 AM
ZachThomas
Sep 3, 2015 01:40 PM
