Finally got to it - throttle body clean / grounding kit
Old Jun 22, 2015 | 11:11 AM
Stachuu's Avatar
Stachuu
Hey folks,
This weekend was nice and I have lots of projects overdue on my car. So last Sunday I knocked off throttle body cleaning and wiring grounding kit.
TB - was pretty nasty, look at the microfiber rag.
.. and of course the DYI grounding wire/kit
Old Jun 22, 2015 | 11:26 AM
Flakman's Avatar
Flakman
Thoughts on the TB cleaning? No issues with idle?
How did you go about cleaning? Did you disconnect the battery first, how did you deal with the tb and plenum when you disconnected? Needing to clean mine (now at 101,000) and want to avoid any TB position relearn issues.
Old Jun 22, 2015 | 11:57 AM
Stachuu's Avatar
Stachuu
I left everything connected, I was careful with not disconnecting any cables on TB as I was cleaning. When I started the car after this was over, the RPM climbed up 2k, then slowly went down to 700. I let the car idle for 10 min. Now everything is fine.
Also I was careful when pushing on the butterfly inside the TB, made sure I didn't let it snap to neutral position, after cleaning edges on the top and bottom.
In the end I think I should have left negative on the battery disconnected to prevent anything goofy happen. Next time I do my spark plugs I will disconnect negative on the battery and do some extra touch up on the TB.
By the way I got 68k miles on the car and the TB o'rings didn't need replacement. So yes I would disconnect battery first, if I was to do it again.
Old Jun 22, 2015 | 08:25 PM
Stachuu's Avatar
Stachuu
Forgot to mention, after installing grounding kit and driving 20 miles, the 7AT shifting is little firmer now in D and DS mode.
Old Jun 23, 2015 | 01:41 PM
tite_tite's Avatar
tite_tite
i did my cleaning about 10,000 miles ago & starting to notice that it needs to be clean again.
i know on my 1st time, i was a little afraid of moving the butterfly to clean so i forgot if i had cleaned it or not.
i think it was kind of stiff in moving so i didn't mess w/ to prevent problems. can you give me some pointers on how you cleaned the butterfly? did you cleaned thoroughly or it was just the edges. thanks.
Old Jun 23, 2015 | 04:36 PM
Stachuu's Avatar
Stachuu
I just used the microfiber towel, sprayed on it TB cleaner and went around the outer sides of the butterfly on both sides. Also same for the outer walls of the throttle body. Than I pushed butterfly on the bottom so it opens.
Since its spring loaded? you need to use your finger to hold it, and other hand to use a rag. Keep the rag moist in the TB cleaner. Its not very comfortable but take your time on it.
I also used smaller allen wrench, because the edge is flat I wrapped microfiber rag over it, spray it with TB cleaner and got into little harder to reach places, that I couldn't access with finger.
Hope it helps. Just take time, once you finish one side, do the other side as the first one dries out. Long story short, don't leave out any tar like residue inside of the TB. Just clean it best you can.
superjoey
31
Mar 22, 2023 11:56 PM
G37xhibeet
Nov 15, 2016 09:29 AM
Landshark
Aug 26, 2015 09:19 PM
JakeG37
Aug 2, 2015 12:00 PM
