another Ds mode question
Old May 28, 2015 | 04:05 PM
tdoug's Avatar
tdoug
Was playing around in DS mode and after getting on it on the highway the car never seems to want to shift higher than 4th or 5th gear on the highway no matter how soft I am on the pedal. It wants to cruise at around 4000RPM. I have to manually bump the shifter up (taking it out of ds auto into ds manual) to get it into 6th and 7th. Does this sound right?
Old May 28, 2015 | 06:50 PM
NickyP's Avatar
NickyP
My 5AT likes to sit at 4K in 4th for a while before shifting into 5th, I think its tuned to the power curve balance between mpg and being ready to pull away if if you push harder on the pedal so it won't have to drop an extra gear. JM2C.
Old May 28, 2015 | 07:49 PM
00Max00's Avatar
00Max00
No, it doesn't. It only holds gears a bit longer on harder acceleration, but will still shift quickly.
Old May 28, 2015 | 11:29 PM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Wow op is this an actual complaint? Not trying to sound rude but thats the whole point of DS mode. To stay in a higher rpm. If you want the rpms down then flip her back over into D. Sometimes mine will take a few before it finally changes gears once on the hwy
Old May 29, 2015 | 12:15 PM
tdoug's Avatar
tdoug
Haha..not a complaint. Just wanted to make sure it was working as it was supposed too. The car just likes to stay around 4k rpm on the highway in ds....if I push it past 4k it will eventually shift to next gear.....unfortunately the police around here do not like the speed I am going by then.
Old May 29, 2015 | 12:24 PM
kuckles27's Avatar
kuckles27
OP. I noticed the same thing. I flip back to D once I'm at a cruising speed. I think it keeps it at 4k to stay in the power band if you want to give it gas so it will take off. I agree it would be nice if the tune would go to higher gear cruising and drop a gear quickly if gas is given.
Old May 29, 2015 | 04:40 PM
guy from norcal's Avatar
guy from norcal
I had the same problem. I got the newest trans update done and it solved that and the shift lag.
Old May 29, 2015 | 06:30 PM
00Max00's Avatar
00Max00
YOu need to have your tranny checked. It will upshift quickly as soon as you release pressure on the gas pedal. "cruise at around 4000RPM" is absolutely not right.
Old Jun 1, 2015 | 05:07 PM
tdoug's Avatar
tdoug
I reset my ecu and other items following this guide and it seemed to have helped. http://www.technosquareinc.com/350reset.htm
Old Jun 1, 2015 | 05:51 PM
malady's Avatar
malady
yes this is why I do not use DS on the highway.
Old Jun 1, 2015 | 08:06 PM
ay37's Avatar
ay37
I keep my 2012 in DS all the time... it goes to 6th and 7th on the freeway for me once it feels i'm cruising, and it picks it up fairly quickly.
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
AMCDeac
General Tech Questions
Sep 19, 2015 05:25 AM
carid
Supporting Vendors
Sep 10, 2015 10:17 AM
joshferbs
Sep 9, 2015 08:53 PM
