Help Those with Okada plasma coils.. Photo attached.
Old Apr 1, 2015 | 11:45 PM
Glover998's Avatar
Glover998
So i got my new Okadas just yesterday and picked up a donor/poor coil to practice with .. Now have a look at the photo below, is this how it should look like when you pop off the coil ?! Also do u see that small white fuse ? that $hit jumped on ma face all of sudden when i popped off the coil, now is it normal or did i snap the hell out of it from the inner springs ? If thats normal, then should i put it back on the same direction as it was sitting in my oem coil ? Cuz i can't figure out how it was sitting in there before i pull it off.
Old Apr 2, 2015 | 02:55 AM
NeverBoneStock's Avatar
NeverBoneStock
Where did you get these and how much?
Old Apr 2, 2015 | 04:57 AM
Glover998's Avatar
Glover998
^ Got em used from a guy in my350Z forum for $530 ( new $1610 )
Old Apr 3, 2015 | 03:49 AM
Glover998's Avatar
Glover998
It's ok i'm not in a hurry ..
Old Apr 3, 2015 | 07:24 AM
Presto's Avatar
Presto
Try posting on the370z, more technical guys over there. Over here it's what vossen wheel, what replica body kit etc that gets the max replies.
Old Apr 3, 2015 | 10:41 PM
Emillion45's Avatar
Emillion45
^ Lmao. Preach!
Old Apr 3, 2015 | 10:53 PM
South3rn's Avatar
South3rn
If it is a fuse, fuses have no polarity. It doesn't matter which way it is installed. I have a little over a half century experience in electronics.
Old Apr 4, 2015 | 01:31 PM
Glover998's Avatar
Glover998
^ That's reassuring .. thx.
Old Apr 5, 2015 | 08:30 PM
Upscale Speed's Avatar
Upscale Speed
How do you like the way they perform? Are yours for a G35 or 350Z? I could;'t find a G37 or 370Z option on their website. $1600 is insanely expensive, but $500 isn't. Did you do a dyno
before and after by chance?
Old Apr 5, 2015 | 09:07 PM
Glover998's Avatar
Glover998
Still didn't install them lol..
I'll let you know once i do that.. but hey, unless you're FI'ed or highly NA built i don't think you'll see any benefit out of them.
Old Apr 15, 2015 | 10:35 AM
Glover998's Avatar
Glover998
Done! just installed them..
Not sure if butt feelin anything but engine seems to be smoother and less NVH, efficient combustion chamber maybe ?!! I don't know..
I think they would work even better with oem .043 spark plugs ( considering that i'm having stronger voltage now). plugs i'm running now are in .030 gap ( too narrow for stronger coils to have their chance to do their job more efficiently ).
Old Apr 16, 2015 | 12:09 AM
Upscale Speed
are you going to swap plugs? dyno runs coming soon?
Old Apr 16, 2015 | 03:39 PM
Glover998's Avatar
Glover998
That's what i'm going to do sir but no dyno runs tho ..
Don't worry i have a very sensitive built-in dyno that never let me down
Old Apr 16, 2015 | 05:24 PM
Upscale Speed
Interested to here the results.
Old Apr 21, 2015 | 04:33 PM
Glover998's Avatar
Glover998
^ Done!
Swapped them for oem plugs and car seems to be waayyyy lighter n pulls a bit harder, So yea ..Okadas do work, at least with my particular setup!
