Help Oil Spraying From BOV
Old Jan 29, 2015 | 02:07 AM
604gz's Avatar
604gz
So after the car being stored for winter the weather finally is warm enough to start my build decided to take the car out for nice drive checked all fluids looks good so i let eveything warm up drove the car slowly to let everything get lubricated in the drivetrain. So i i went to a performance shop to pick up some liqui molly 5w40 4100 oil since my last oil change i used mobil 1 and i noticed when i popped the hood there way quite a bit of oil on my hood rad hose ect now i am paniking thinking it is blow by so i get the mechanic to take a quick look he says its not blow by phew. He is saying that it is normal to have that espicially with STI's. He recommended to get an engine flush and drive it around and see if it continues? After doing some research i think the issue could be that 1. The mobil one oil after sitting all winter sludged up 2. Too much oil going to the turbos and not draining fast enough 3. Pcv is clogged? only the passenger side bov is blowing oil both air firlters seemd like they had oil leak out of them. Anyone else have this issue before?
Old Jan 29, 2015 | 02:56 AM
Synolimit's Avatar
Synolimit
Originally Posted by 604gz
So i went to a performance shop to pick up some liqui molly 5w40 4100 oil since my last oil change i used mobil 1 and i noticed when i popped the hood there was quite a bit of oil on my hood and radiator hose and now i'm panicking thinking it's blow by. so i get the mechanic to take a quick look he says its not blow by, phew. He is saying that it is normal to have that espicially with STI's. He recommended to get an engine flush and drive it around and see if it continues? After doing some research i think the issue could be that 1. The Mobil one oil after sitting all winter sludged up? 2. To much oil is going to the turbos and not draining fast enough? 3. PCV is clogged? Only the passenger side bov is blowing oil. Both air filters seem like they had oil leak out of them. Anyone else have this issue before?
1. Mobil is like water, dump it. Lol it won't sludge up but then act like water and spray out of everything.
2. All cars have blow by, you have to or the bottom end would explode.
3. Sounds like all your hoses are OEM still. Vent the PCV's to atmos after you run them to an oil catch can and get rid of any hoses going to the mani that aren't needed. You can vent the hoses going to the intakes too. This will eliminate any chance of oil getting into the intake system besides the turbo rings, all turbos are not 100% leak free just like a piston ring. Oil will leak out into the turbine and compressor.
How can an air filter leak oil? It's the first item in the system. Things go in, not out.
Old Jan 30, 2015 | 03:49 AM
604gz's Avatar
604gz
Thanks for the help i really apperciate it! So i spent most of the day today cleaning the pipes and and the amount of oil i noticed on my that has leaked around both my air filters, chassis, and all over the splash sheild its quite a bit enough to make a pretty good differance on the dip stick. I was able to soo that the oil on the passenger side is clearly coming from the BOV but on the drivers side i have no been able to pin point exact location yet.
Old Feb 1, 2015 | 03:36 PM
604gz's Avatar
604gz
So i checked all the pcv lines and ect and they are all clean. I decided to take off the front bumper as of what i said earlier oil was comin out of my air filter, and it turns out i was right about the oil leaking out of my air filter. the turbo ball bearing seals on the drivers side is toast time to get them both serviced!
fuzzed
Aug 21, 2020 09:35 AM
GeezerB
Car Care & Detailing
12
Jan 23, 2017 07:00 AM
Stevolkz33
May 28, 2016 02:36 AM
Junchao Sun
25
Oct 1, 2015 12:41 PM
Chappedj
Sep 28, 2015 03:20 PM
