STILLEN Black Series Superchargers Now Available!!!
Old Nov 20, 2014 | 10:32 AM
G37Xtreme's Avatar
G37Xtreme
Originally Posted by ANMVQ
Their SC is not Air/Air its AIR/Water, the Frozen boost is a "heat" exchanger is cools the fluid, It works similar to a radiator. It' WAY more efficient than the one that comes with the kit tho so GREAT move on changing it!
Are you referring to the radiator/intercooler looking contraption? So it doesn't rely on passing air over fins, instead, it runs coolant through channels? Is this standard engine coolant (do you tap into the car's coolant supply?)
I still can't figure out how the air goes through it. It seems to be half the thickness of the tube diameter. If air passes through it, how is it not a bottleneck considering it's slender size compared to the air tubing?
Are the air connections in the back? Does it mate with the intake tube at the diameter of the tube, or is there a major neck-down?
Old Nov 20, 2014 | 10:58 AM
Diego@Vossen's Avatar
Diego@Vossen
Old Nov 20, 2014 | 11:30 AM
ANMVQ's Avatar
ANMVQ
You just removing the stillen heat exchanger and replacing it with the frozen boost one, You'll mount this in the front of the car to the rad support like a intercooler. Look at Diego's car pics
Old Nov 20, 2014 | 11:34 AM
G37Xtreme's Avatar
G37Xtreme
That makes perfect sense now. The intake manifold has a built in cooler (which also explains my first question regarding the shape of the thing), and only coolant passes through the intercooler looking thing (heat exchanger).
Old Nov 20, 2014 | 11:46 AM
Diego@Vossen
Here is how she looks with the new cooler!
Old Nov 20, 2014 | 03:11 PM
G37Xtreme's Avatar
G37Xtreme
I'm not ashamed to admit it.
I came
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
SchoonerVanHlmt
Intake and Exhaust
Sep 20, 2015 01:03 PM
abretz89
Aug 20, 2015 11:58 PM
Jensen Mathew
Aug 16, 2015 08:06 PM
