Review World Record NA VHR Build
Old Oct 28, 2014 | 03:36 PM
warpeacelove's Avatar
warpeacelove
Link to the source: World Record NA VHR Build - Nissan 370Z Forum
Okay due to much requesting here is a run down of the build and parts used. The car is an 09 sport 6mt and since I live near GTM I dropped by and went over what I wanted with Sam and went ahead and dropped my car off. The project was set to take a Mid level approach to an NA build as I wanted to see what could be done on the stock block and heads, and I also wanted to prioritize mid range power to suit my driving style and only moderately increase Upper rpm power. The plan was layed out to include a new manifold and fuel rails, new throttles, new intakes, new headers, open exhaust but still quiet enough to drive it around, a bulletproof clutch setup, dry sump oiling, increased cooling, and to run dual fuels and see if there was any gain to be had on E85. *as I get more pictures sent to me I will add them in here*
For the manifold it was decided to go with the GTM ITB setup, but it was custom converted to twin 3" throttles and DBW to run on the factory ECU(VHR throttles would also work so that the setup could be used on a car without swapping the throttle bodies). To go with the bigger manifold and throttles a new 3" cold air intake was fabricated using two GTM stage2 supercharger 5" air filters and velocity stacks to make sure the air had a completely unrestricted path to the valves for maximum power. As I track the car occasionally it was a must that the whole setup fit under the factory strut bar as well. New billet fuel rails were made to match the new runners and setup to supply them from the factory returnless fuel line was made since going returnless wasn't worth it at this point in time.
In order to spin the car up past 8000rpm more reliably as well as avoid any oil supply issues a dry sump was decided upon to lubricate the motor. I looked into the existing Dailey's Engineering kit and was going to purchase it until i got the final price and broke out in a cold sweat, since the pan and pump was $7000, needed a custom solid aluminum motor mount, and there was like $10k additional in parts to get the pump to fit with the accessories and actually make the system work. After talking to Sam I decided to let GTM develop a new cost effective solution to this problem and he came through with a Billet oil pan, Peterson Fluid Systems R4 4-stage drysump pump, and peterson tanks,breathers, filters. In order to keep the costs down it was decided to make a billet bracket to replace the air conditioning with the pump and make the pan so that lines could be run to it. The A/c can be reinstalled down the road by using the GTM Bracket kit to move the alternator and power steering up and mounting the pump on the passenger side but for now I decided to save a couple grand and drop the weight of the a/c system. Oil capacity is now 12.5 quarts and I need to install a smaller cooler in the system as my oil temps have not gone over 190 since the system was installed. The kit also uses a high capacity racing oil filter and light wieght synthetic braided AN line for the low pressure side and stainless on the pressure line for safety. A peterson Vacuum regulator and new breather set up had to be fabricated to control the engine vacuum generated by the massive new oil pump down to 14"Hg. The vacuum pulled by this pump eliminated windage and gave us a nice Hp gain as well. To drive the pump, an adapter was made to reuse the factory crank pulley, but since I had saved money on the system I opted to go for the full ATI underdrive super damper setup Sam has to help out with high rpm crank vibration as well.
For cooling I decided on the GTM 70mm radiator and reusing my OEM fan assembly as well as a flush and switch to the nissan blue coolant, simple and effective.
In order to never worry about the clutch hydraulics it was decided to replace them with all new race worthy components. GTM came up with a Tilton racing hydraulic release bearing setup, with a new tilton large bore master cylinder for lightning fast clutch release and engagement and to make it so other people don't want to drive my car haha(it's really heavy). While I was in there I opted to go for an OS Giken Grand Touring twin plate as well to cope with future abuse, and a GTM bolt on clutch pedal stop to shorten my shift times.
After Dynoing the car with the above it was decided that there were serious exhaust issues and air was backing up in the engine(as well as my head gasket had blown) so to free up the breathing a set of JUN 11mm lift 282 duration exhaust cams was installed and a set of Z1 headers was ordered and modified by GTM for the car with VHR flanges to work with the existing GTM resonated test pipes.
To support the higher fuel demands of E85 a set of 600cc injectors and a Walbro 255lph pump was installed to work with the new rails and modified returnless setup.
After that I pulled the car out and got some Nismo's, and worked on the suspension while I waited to get it tuned, which was decided to be done at Specialty Z. After talking to Seb and leaving him the car Uprev was flashed and final tune results ended up at 361whp/290wtq on 91octane and 371whp/296wtq on E85. Torque is plentiful on both fuels with E85 having more than 275lb/ft available from 3500-6500rpm and with horsepower continuing to build past 8200rpm. For the graph the Green line is stock, the Dark BLue line is average bolt-ons the red line is E85, and the blue line is 91oct
File Type: jpg
File Type: jpg
Old Oct 28, 2014 | 04:56 PM
PongSanity's Avatar
PongSanity
Extensive as well as expensive build setup. Respect.
Old Oct 28, 2014 | 05:02 PM
warpeacelove
You can say that again. $$$$$. GTM always have something up their sleeves.
Old Oct 28, 2014 | 05:04 PM
conkus805's Avatar
conkus805
I got to see this car in person at specialty z this past week while Gettin my gears done, the manifold is even more beautiful in person.
Old Oct 28, 2014 | 05:07 PM
I stopped reading when I got GTM. Literally. F this build and anyone associated with it. Pay people their money back you thieving scumbags.
Old Oct 28, 2014 | 05:25 PM
conkus805's Avatar
conkus805
^^^^^^^Lol! So true
Old Oct 28, 2014 | 05:26 PM
hizzle101's Avatar
hizzle101
wow GTM doing some good work!!
Old Oct 28, 2014 | 06:24 PM
antirice's Avatar
antirice
I thought GTM filed for chapter 11.
Old Oct 28, 2014 | 09:24 PM
warped ideas's Avatar
warped ideas
A quarter past stripped
Didn't some guy a few months ago have serious issues with his Stage II GTM Twin T set-up GTM wouldn't honor their own warranty saying something about oil consumption when it was proven with photos that it was an oil leak? Anyway, lots of $$$$ to spend for an NA setup.
Old Oct 28, 2014 | 10:22 PM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
What?!? GTM is still alive?
Old Oct 28, 2014 | 11:14 PM
alfredo24pr's Avatar
alfredo24pr
There is a guy that posted on my local g37/370z page that he had been waiting 9 months for his GTM supercharger kit. Feel kinda bad for him.
Wth is GTM even thinking..? 9 months?!
Old Oct 28, 2014 | 11:36 PM
twin_snails's Avatar
twin_snails
What he said. I was under the impression they filed for Ch. 11 as well...
Old Oct 29, 2014 | 05:25 AM
dtea54's Avatar
dtea54
This is money ! Perhaps this is to consider down the road.
Other then the bad rep this is somewhat rare to see. Also what is chapter 11 short for ?
Old Oct 29, 2014 | 06:40 AM
Synolimit's Avatar
Synolimit
STD, all I have to say.
Old Oct 29, 2014 | 06:59 AM
blueis300's Avatar
blueis300
Reorganization Under the Bankruptcy Code
The chapter of the Bankruptcy Code providing (generally) for reorganization, usually involving a corporation or partnership. (A chapter 11 debtor usually proposes a plan of reorganization to keep its business alive and pay creditors over time. People in business or individuals can also seek relief in chapter 11.)
Chapter 11 in general[edit]
When a business is unable to service its debt or pay its creditors, the business or its creditors can file with a federal bankruptcy court for protection under either Chapter 7 or Chapter 11.
