Slave cylinder and concentric slave cylinder
Old Oct 23, 2014 | 02:43 PM
kw`'s Avatar
kw`
so im buying a new slave cylinder and want to know if there is any difference between these two? (Slave cylinder vs. concentric slave cylinder)
Old Oct 23, 2014 | 03:17 PM
canucklehead's Avatar
canucklehead
for our cars, no. CSC is the common reference. it takes the place of a traditional throwout release bearing. if your car is out of warranty and you are paying out of pocket you might want to look into the heavy-duty CSC units available in the aftermarket. lots of guys go that route to avoid future problems.
i'm assuming your original CSC failed on you. i recommend changing the clutch master cylinder while you are at it. they sort of go hand-in-hand and if you are keeping the car for a while it would be prudent. i just had my CSC done under warranty (nissan parts, not HD unit), but i paid extra to have the master cylinder done at the same time. then the dealer flushed/bled the hydraulic fluid with "GTR" fluid under warranty as well.
eljoker
Future Models
19
May 30, 2022 11:48 AM
ZSpeedPerformance
Drivetrain
12
Sep 9, 2016 11:20 AM
stevo4756
Oct 9, 2015 01:54 AM
r0cketm0nkey
Sep 18, 2015 10:16 AM
