6MT diff install progress
Old Nov 22, 2014 | 05:48 PM
  #76
alfredo24pr's Avatar
alfredo24pr
What was your best trap speed?
Old Nov 22, 2014 | 06:16 PM
  #77
Solidus's Avatar
Solidus
Gimme a few and I'll post up.
Old Nov 22, 2014 | 07:54 PM
  #78
Solidus's Avatar
Solidus
Fastest was 104.98 I blame that on the gears. Like I said though a harder launch and a tune would probably give me time to stretch out. Dunno if you understand log files but here's a screen shot of my 0-60 log near the end . On the right side you'll see the speed and the two rows show left and right bank wideband afr's. These are near shift point.
Attached Thumbnails 6MT diff install progress-screenshot_2014-11-22-19-38-42.jpg
Old Nov 22, 2014 | 09:13 PM
  #79
alfredo24pr
I can't understand that lol.
Still want to see the times and trap speeds after being tuned.
Also, what wheels and tires are you running?
Old Nov 22, 2014 | 09:20 PM
  #80
Solidus's Avatar
Solidus
19x9, 19 x 10 STR 607. 245 , 285 Hankook Ventus. I'm gonna snag a rear 18 x 10 and a set of 285/35 18 Nitto drag radials.
Old Nov 22, 2014 | 09:22 PM
  #81
Solidus's Avatar
Solidus
12.8 is where I want to be for the afr's but it's lean in the mid 13's.
Old Nov 22, 2014 | 09:43 PM
  #82
alfredo24pr
You should try with the 18" wheel, especially if it is lightweight.
Those wheels are heavier than stock, but the tires bring it down for a total of 2lbs saved, so the wheels are not the problem, but 18's would help a lot. The coupe however, will look a lot less luxurious with 18's
Just get 2 light and cheap wheels for the rear with sticky tires just for the track. You will easily get down to the 12s without a tune.
Old Nov 22, 2014 | 10:31 PM
  #83
JT2014's Avatar
JT2014
I was expecting more.....13.4's isn't that bad considering no tune.
Those handkooks also are terrible track tires. I had a set on the SRT8 & my Acura CLS & traction on the track sucked.
Old Nov 22, 2014 | 10:41 PM
  #84
Solidus's Avatar
Solidus
If you listen to that little burnout I did. Then listen to the launch you'll see that I spun the whole first gear. We'll see after the tune. Next up 18's and if that fails. 3.91 gears.
Old Nov 22, 2014 | 11:08 PM
  #85
alfredo24pr
I'm optimistic that the 18's with good track tires will be enough. Won't the 3.91 cause even more spin?
Old Nov 23, 2014 | 08:36 PM
  #86
Solidus's Avatar
Solidus
Finally had time to put up the slips. 1st slip was my shifter catastrophy. I know now to stay away from it on launch. Had I got that right I think I would've been where I wanted to be. I'm left lane #62. First three runs vs. a Boss 302 having problems and the last run is the STI from the video.
Attached Thumbnails 6MT diff install progress-2014-11-23-19.53.24.jpg   6MT diff install progress-2014-11-23-19.54.04.jpg   6MT diff install progress-2014-11-23-19.54.47.jpg   6MT diff install progress-2014-11-23-19.55.19.jpg
Old Nov 24, 2014 | 04:00 AM
  #87
dgey1's Avatar
dgey1
nice numbers dude. Torque converter, slicks and a tune and I think you'll be where you want to be. A tune is important. The TC may be more beneficial than 3.916 gears. 13.414 is a good number with just bolt on's. good job.
Old Nov 24, 2014 | 02:31 PM
  #88
Solidus's Avatar
Solidus
Tune just came in. I'll re flash the ecu tonight, do a fuel reset and drive it a few days before I log. Shooting for 12.8 afr's again.
Old Nov 25, 2014 | 08:57 PM
  #89
SharpByCoop's Avatar
SharpByCoop
Good work. My first time at a track with ANY combination is always a bit of a disappointment. However, we pay attention to what's needed, and regroup.
That you went and posted true results is testimony of your diligence. (Unlike the '800 hp' Infiniti poser somewhere here.... )
18" drag radials minimum. Beyond that, get a torque converter.
Nice.
Old Nov 26, 2014 | 12:27 PM
  #90
Solidus's Avatar
Solidus
Thanks Coop, running with the tune now for the 2nd day I can say I really do feel a little mid range difference. Still haven't logged anything yet to allow the ecu to adapt but I'm hoping it settles in on the fuel target of 12.8 . Once I get that settled , I'll do the "Burnout Mod" I used on my Titan to allow me to launch without pulling timing and fuel. I believe I'm just going to go from the brake pedal but on my Titan I did it from the ECM module and that allowed me to keep the brake lights. I'm thinking a higher launch rpm and 20psi on street tires with no burnout at all ( First run I had a 1.9? 60ft with 45psi but I didn't spin the tires at all ) If I can bring all this together I'll be that much closer. After getting those few runs in I'll work on a set of NT555R's in 18 plus some wheels. If that takes me to a 12.8 or better I'll do the converter and set myself up to be the quickest N/A G Coupe.
