Help with Replacement Clutch
Old Sep 26, 2014 | 01:14 AM
johnnym's Avatar
johnnym
Question Help with Replacement Clutch
Have an '08 6MT, pretty much no mechanical savvy (only car I ever worked on was a VW on Guam 30+ yrs. ago 'cause nobody worked there).
Clutch is nearly gone @ 45K miles; true OEM replacement costs ridiculous amount & I'm getting conflicting info from alleged experts about the way to go. Many people say that the dual-mass flywheel is likely still good...so just replace the rest and save a grand while still using true OEM parts everywhere else. Local Transmission Specialist says the dual-mass flywheel being trusted or re-worked is foolish cause most are bad or go bad shortly & that grinding won't work. What, if anything, am I sacrificing if I go the route of a Complete Kit from someplace like Exedy...thus eliminating the dual-mass element that is so costly & ending up with all new components, albeit not OEM & no more forgiving absorption afforded by a dual-mass flywheel. Any help is greatly appreciated
Old Sep 26, 2014 | 11:02 AM
PongSanity's Avatar
PongSanity
South Bend stage 1 clutch/flywheel combo on concept z performance. . You're welcome.
Old Oct 10, 2014 | 03:07 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
May all your problems go away, This is what we recommend for a complete fix of the dreaded stock clutch problems, If you are not going to upgrade the Stock CSC stick with the stock clutch and stock CSC and hope for the best.
ZSpeed Performance South Bend Complete Clutch Package Stage 2 Daily 370 G37 G35
redlinernyc
Feb 29, 2016 11:06 PM
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
joshferbs
Sep 9, 2015 08:53 PM
inspector94
Sep 8, 2015 12:57 PM
ZachThomas
Sep 3, 2015 01:40 PM
