Failing Crankshaft Angle Sensor
Old Sep 1, 2014 | 02:54 PM
beto4632's Avatar
beto4632
Question Failing Crankshaft Angle Sensor
I have a 08 g37, ive been experiencing some problems with the car. It stalled on reverse at low speeds I have to give more gas than usual or the car hesitates. Also when im at a complete stop the car try's to turn off and all i see in the gauges is the battery light i also have to give it more gas in order for that not to happen. Another thing is when im driving at 35-40 mph the car jumps i keep it at a steady speed but it keeps happening.
I was reading online that it could be a failing crankshaft sensor, just dont know were they are located. Has anybody had this problem before.
Old Sep 1, 2014 | 03:10 PM
FXG37S's Avatar
FXG37S
Have you ever cleaned the throttle bodies? Try that first. Some of the symptoms you describe are similar to dirty, gunked up t-bodies. There's a DIY somewhere on here. Hope this helps.
Old Sep 1, 2014 | 06:32 PM
dkmura's Avatar
dkmura
20 Year Member
Rather than guessing about what is wrong, why not use a code reader? A failing CAS usually manifests itself as a loss of power until the engine simply quits.
Old Sep 1, 2014 | 06:49 PM
beto4632's Avatar
beto4632
TB are fairly clean, I Don't get any check engine light and I did run it on a obd2. But no codes popped up
Old Sep 2, 2014 | 07:12 AM
FXG37S's Avatar
FXG37S
The only other item I could think of that might cause that is the idle control valve, which I believe is built in to the throttle body. This is just a guess, with the info you provided. You scanned it and did not retrieve any codes??
Old Sep 2, 2014 | 08:10 AM
ANMVQ's Avatar
ANMVQ
No codes ? If not your for sure guessing, Could be a vacuum leak also
Old Sep 2, 2014 | 12:36 PM
HoldmyMouse's Avatar
HoldmyMouse
MAF sensor?
Old Sep 2, 2014 | 08:33 PM
brizey's Avatar
brizey
I thought the G37 Sedan did not come out until the 2009 MY.
Old Sep 2, 2014 | 10:19 PM
beto4632's Avatar
beto4632
Yea no codes, and no check engine light.. It wont do it until the car is running for about 20 min or so. I was reading on another post that it could be the "ITB" i just dont know what that short for. Thank for all the responses!
http://x.infinitihelp.com/forum/show...64.html?t=9064
Old Sep 3, 2014 | 07:24 AM
FXG37S's Avatar
FXG37S
ITB= Infiniti Technical Bulletin
Old Sep 3, 2014 | 07:33 AM
FXG37S's Avatar
FXG37S
Seems like there is a software update needed when the conditions you describe exists. Dealer.
fuzzed
Aug 21, 2020 09:35 AM
vamarris
Dec 9, 2018 11:10 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
2K1 6T8
Oct 6, 2015 07:40 PM
