Review Intake & Tune - Let's see how this goes....
The following 2 users liked this post by conkus805:
Diego@Vossen (07-24-2014),
Rannysg37 (07-24-2014)
Baseline, 270whp 220wtq. There is definitely more to be gained. Will update with final numbers later. Third gear pull lost a little traction mid run, so lost some of the peak torque numbers;-) temperature is 100 deg, so numbers may be a little low.
Waiting for the car to cool before final runs, but I am extremely satisfied with the numbers my car has made. The final peak numbers in third gear are 281whp and 234wtq, the real story is told in the low and midrange rpms with consistent 20wtq and whp gains with some areas of 30wtq gains. To say I'm satisfied would be an understatement.
twin_snails (07-24-2014)
Run 1: Max Power = 255.71 Max Torque = 227.96
Run 2: Max Power = 268.70 Max Torque = 247.26
Run 3: Max Power = 270.24 Max Torque = 243.15
Mine is a 7AT so I was pretty pleased with those results for stock. Getting FI CBE and RHFC's installed on Saturday already have the Takeda CAI installed. Will probably do an UPRev tune later in the month. It'll be interesting to compare results.
Thanks for taking the time to post your results with the ECUTek tune!
How many maps did your tuner do for you on the ECUTek? Can't remember if you have a 7AT or not but did he make any changes in the trans?
#29
Twin, you should come back and report your results in this thread. The power increase is definitely noticeable at all rpms and makes the car feel l like it should from the factory, it even sounds different. At this time there is no ability for tuners to add maps like Uprev so your stuck with your tuned map for now. Seb did not adjust the trans at all, I really didn't want to change anything because I like how it shifts. The extra torque is just wonderful, it was something that my car was lacking. Oh and twin, my car is a 7at. So I got almost 300 at the wheels with intake exhaust and ecutek tune. Not too shabby.
twin_snails (07-26-2014)
