anyone put 6mt 3.69 gears in 7at
#121
Can someone with 3.692 gears in a 7at G37 tell me what your RPM is while cruising at
60
70
80
or any speed in between?
I recently installed what I thought was a 3.692 rear end but now I'm starting to think I installed a 07 G35 Coupe diff which is 3.538.
60
70
80
The following 2 users liked this post by stealthee:
krazyfiend (12-11-2017),
qmantran (12-10-2017)
#123
Thanks a lot stealthee. So with my factory 3.357 I took pictures of the rpm before I swapped it out. Here are what they were vs new diff.
3.357 2011 G37S 7AT RWD
Swapped diff from a 07 G35 "KG" stamped + labeled (3-bolt pinion flange)
So I may indeed have 3.692 FD.
- 60mph - 1950rpm
- 70mph - 2300rpm
- 80mph - 2600rpm
- 60mph -2150rpm
- 70mph - 2550rpm
- 80mph - 2850rpm
#124
was just able to get up to 60 in 7th on my commute into work this AM. 2150rpm is right on and coordinates with stealthees mechanical leverage against speed, rpm calculation.
qmantran (12-11-2017)
redlinernyc
02-29-2016 11:06 PM
inspector94
09-08-2015 12:57 PM
