Engine choking at acceleration after 2k RPM
Old May 12, 2014 | 11:04 AM
Polar_g37s's Avatar
Polar_g37s
I'm in Toronto. I can scan your car for free if you can get to my place.
Old May 12, 2014 | 08:29 PM
orson8888's Avatar
orson8888
go autozone they check for free, could be spark plugs or igniton coils
Old May 12, 2014 | 09:19 PM
g37smtl's Avatar
g37smtl
I'm towing the car to the dealer tomorrow morning, I will let you guys know what is the problem.
Old May 13, 2014 | 04:18 PM
g37smtl's Avatar
g37smtl
I brought the car to the dealer this morning, they called me, they don't know what is problem, the noise that I thought was the serpentine belt, they say it is not, that the noise is coming from the engine, How come the engine can make a high scratching noise?! The check engine light is off now, they want 600$ to dismount the engine to know where the problem is and we are not even counting the repare cost...... What should I do, please help me....
Old May 13, 2014 | 04:26 PM
hinomura's Avatar
hinomura
oh god man that sounds like a nightmare. I wish I knew how to help. Just bumping this thread for you in the hopes someone else sees this and can chime in.
Old May 13, 2014 | 04:29 PM
g37smtl's Avatar
g37smtl
yes it is a nightmare, tomorrow I am going to talk to the manager to work something out
Old May 13, 2014 | 05:04 PM
g37smtl's Avatar
g37smtl
I called a towing guy this morning, he said this is the alternator, he charged my batterie and the car worked, can it be the alternator which is the cause of all this, and the dealer just wants to make me pay extra, can the alternator cause that noise
Old May 13, 2014 | 05:56 PM
2008G-Man's Avatar
2008G-Man
Any moving part can make just about any noise so it could be. With your car running you should be around 14 volts at the battery. Get a volt meter and check.
Old May 13, 2014 | 06:21 PM
monytx's Avatar
monytx
Any Autozone will check codes for you for free. Does Canada have Autozone?
Old May 13, 2014 | 09:46 PM
Lafittez's Avatar
Lafittez
Yo your car went into limp mode. theres a ton of reasons for that. For one cleaning the mafs and throttle bodys can cause limp mode. If the electrical system gets to low it will send the car into limp mode. Biggest issues with our cars are... Throttlebodies wigg out which means youll have to do a throttlebody relearn... Next is security keys. If your car looses reception of your fob it can throw it into limp mode. My best advice for you is to purchase uprev. Its a tuning system so you can read and clear codes. also datalog things like voltage etc etc
Old May 14, 2014 | 09:28 AM
RPG11's Avatar
RPG11
I cleaned the throttle bodies after the problem surfaced, they looked normal to me
I cleaned hers too but it didnt work. go to ebay and buy the obd2 torque to connect it with your laptop is only like $30-$40. And i bet the code is throwing is P2004. look it up on the internet.
redlinernyc
Feb 29, 2016 11:06 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
