Oil for upgraded AT?
Old Jan 24, 2014 | 07:04 PM
martalex's Avatar
martalex
Hello,
Can you explane me please if is there a difference between a stock AT and upgraded (actually GTM Stage 4)? I mean wich oil have I to use? Normal Nissan Type J or some other?
Does anybody have such experience?
Thanks
Old Jan 24, 2014 | 07:13 PM
Deelow's Avatar
Deelow
What is the year and model of your G?
Old Jan 24, 2014 | 07:23 PM
martalex's Avatar
martalex
G35x sedan 2008
Old Jan 24, 2014 | 07:31 PM
Deelow's Avatar
Deelow
I'm not 100% sure on a 08 but for 2010 an Infiniti master tech I spoke to said that Infiniti recommends never changing it unless there is a problem. In that case they inspect the transmission and unless there are significant shavings in the fluid, it's just a drain and fill. Anyone here have an 08?
The 2010 and up have a full synthetic fluid from my understanding.
Old Jan 24, 2014 | 08:01 PM
martalex's Avatar
martalex
Thanks... My mechanics think the same way..
But they never upgraded Nissan's transmissions up to 750 hp therefore asked me to specify from the seller of this upgrade ... but unfortunately for me it's very difficult to get something from GTM... they ignore my questions or don't respond for weeks
Old Jan 24, 2014 | 08:31 PM
Deelow's Avatar
Deelow
Hopefully someone else on here has some experience with this problem.
Old Jan 25, 2014 | 04:38 AM
martalex's Avatar
martalex
Subaru mechanics use for their upgraded transmission not OEM oil but more high-temperature oil because thansmission works at higher loadings...
Logically it must be the same on Nissans...
I hope there is someone who has the same transmission... I'm the first on the Ex-USSR terrotory who does such deep upgrade to the Infiniti so I have nobody in Ukraine to help me...
Thank you very much for the help
Old Jan 26, 2014 | 03:07 PM
martalex's Avatar
martalex
I found a guy in Russia with 350Z with the same GTM transmission... His answer is:
ONLY NISSAN MATIC J
He uses his AT for 2 years without any problems
So I have the answer on my question.
delfinparis
Nov 16, 2015 02:26 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
djdiskino
Sep 29, 2015 07:18 PM
Chappedj
Sep 28, 2015 03:20 PM
Allboutcali
Sep 26, 2015 03:43 PM
