Help After A/C compressor replaced ..
Old Jan 18, 2014 | 10:38 PM
Glover998's Avatar
Glover998
So i replaced my A/C compressor for a new one , but got a problem later on ..
when i switch off the A/C, an abnormal scary sound comes out from the engine, tried to trace it down but with no luck .. it's like a ringing bell / clinking metal sound .. it continues for 3 seconds only.. clickclickclickclickclick metal sound, thats how i wud describe it
This happens the moment i switch off the A/C Only and continues for 3 seconds only
Note: old compressor was totally jammed, do you think it has damaged something inside while attempting to run the A/C ?!! adjuster maybe ?!
Your help is so appreciated ..
Thank you in advance..
Old Jan 19, 2014 | 12:02 AM
Can you possibly make a video of it?
Old Jan 19, 2014 | 02:18 AM
Glover998's Avatar
Glover998
i don't have the car right now, i dropped it with some guy for couple days .. Meanwhile, you may want to share your initial thoughts/doubts plz .. thank you.
Old Jan 19, 2014 | 04:58 AM
Glover998's Avatar
Glover998
anyone ?!
Old Jan 19, 2014 | 07:05 AM
G37Sam's Avatar
G37Sam
Your description is a little vague I'm afraid. Could you get your friend or anyone to record it at least?
I would get the car on a lift, remove the plastic undercover and have someone start the car while you inspect from underneath. You should see/hear it then. Inspect the belt maybe?
Old Jan 19, 2014 | 07:35 AM
Glover998's Avatar
Glover998
-No need to go underneath .. sound level is as loud as someone ringing a bell right behind your ears lol.
-sound remains for almost 3 seconds right after you switch off the AC only.( No issues when start A/C, running the car whatsoever ).
-sounds pretty much like a constant clickclickclickclick metal sound
Old Jan 19, 2014 | 08:00 AM
G37Sam's Avatar
G37Sam
But you still can't trace where it's coming from?
Old Jan 19, 2014 | 08:12 AM
Glover998's Avatar
Glover998
No
couldn't figure out where exactly it's coming from but it's kinda from the front end of the engine, sound coming from that whole area .. i couldn't really point it out where its exactly... pullyes , adjuster, alternator .. i don't know
Old Jan 19, 2014 | 08:16 AM
G37Sam's Avatar
G37Sam
No
And that's exactly why I recommended you look under with the cover off.
Old Jan 19, 2014 | 08:38 AM
Glover998's Avatar
Glover998
Ok mmm.. What pulley does the compresser belt rotate with ?! crank pulley ?!
Old Jan 19, 2014 | 01:48 PM
G37Sam's Avatar
G37Sam
Old Jan 20, 2014 | 02:12 AM
Glover998's Avatar
Glover998
^ Thank you Sam
Raleclair
Oct 8, 2015 02:06 PM
joshferbs
Sep 9, 2015 08:53 PM
Peepz
Sep 9, 2015 06:51 PM
ZachThomas
Sep 3, 2015 01:40 PM
