weird question
Old May 21, 2013 | 08:36 AM
mosesuu's Avatar
mosesuu
weird question
Has anybody noticed when your driving 115 + that your clutch feels a little spongy after and then goes back to normal after 10 seconds or so of slowing down
Old May 21, 2013 | 09:57 AM
JSolo's Avatar
JSolo
Just say no!!!!!
You mean driving 115 mph on the track?
When was the last time your clutch fluid was flushed?
My guess the spongyness is due to the additional heat generated by the engine which causes whatever moisture is present in the fluid to boil, thus generating air in the line.
There's a tsb for the 370's that involves changing out the stock fluid for the gtr brake fluid (DOT 4). IMO, any decent high perf dot4 brake fluid with a high wet boiling point should work for street applications. For track, you probably
want something with an even higher wet boiling point.
Old May 21, 2013 | 10:06 AM
Kevalteam's Avatar
Kevalteam
always add on track~ ^^
Old May 21, 2013 | 11:58 AM
mosesuu's Avatar
mosesuu
Yeah on the track. Thanks for the info just bought the car in February and I need to change the fluid
Old May 21, 2013 | 02:40 PM
ttv36's Avatar
ttv36
Race, repair, repeat.
^ Also changing to a SS clutch line may help.
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
si_driver
Sep 12, 2015 10:38 PM
rgonz
Sep 11, 2015 04:07 PM
johnadlertech
Sep 11, 2015 02:07 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
