Uprev cooling Fans control
Old 09-20-2012, 02:21 AM
advan37
advan37's Avatar
I'm just wondering , if anyone tried to set the cooling fans to come on earlier .
Factory setting is around 98c (210F) to have the fan runs at full speed.
Yesterday my tuner tried to log in and do the changes but unfortunately he couldn't do it (because the map only works with 2009+ models and mine is 2008).
Old 09-20-2012, 08:53 AM
Q8y_drifter
Q8y_drifter's Avatar
You will need to contact Jared at Uprev and see if he can update your cable for the fan control. I'm not sure how that works out though since I haven't done that yet.
Anyhow, in stock form, the fans start working at 98C coolant temp, however they only work at a duty cycle of about 40% or something in that range. And I can't remember if only one or both fans work. Either way I think the fan settings as well as the thermostat temp rating are too hot for the HR and even more so for the VHR. And being in the GCC in 130+F heat does not help at all.
Old 09-20-2012, 10:58 AM
seymore4
seymore4's Avatar
Fan control has nothing to do with the cable its in the vehicle specific rom file. If the rom has that feature then any tuner can do it.
That being said I do not believe that its a 09 and newer thing, just that VHR's benefit most from it
Old 09-20-2012, 05:09 PM
advan37
advan37's Avatar
We contact Uprev and they working on it , when ac switch on only one fan will work the other one will engage after the temp reached to 98c which I think it's too much.
I do have lower temp thermostat 66c and it's great , but still I need to set the fans to kick earlier.
Old 09-20-2012, 05:12 PM
advan37
advan37's Avatar
It been tested on 2009+ models and it work perfect with them .
Old 09-20-2012, 05:23 PM
seymore4
seymore4's Avatar
The option is there for most roms that I've looked at
Old 09-20-2012, 06:15 PM
fairladyz34
fairladyz34's Avatar
it worked on mine. 2008 sport coupe
Old 11-11-2012, 01:34 AM
slims
slims's Avatar
Advan do you have the Mishimoto Racing T-stat? the 66c/150f one?
I saw that MotoRad makes one too but it is a 82c/180f T-stat.
With the known heating issues the VHR's have, I'm thinking this will probably be my first mod...but I was wondering which one is better and how difficult is the tuning to have the fans adjusted to activate earlier on the 2009 G37 Journey? Thanks in advance for the info.
Old 11-11-2012, 05:59 PM
seymore4
seymore4's Avatar
Its very simple, but you will need to purchase an osiris license to do it. PM me if you want to save some money and aren't set on a full dyno tune, I can help you out
Old 06-20-2019, 09:55 AM
Grash73
Grash73's Avatar
Might be old news to you all, but my tuner just set my fan to come on at 170 F and lowered the setting for coolant temperature to stop throwing code PO128 coolant temp to low . for free took about a half hour. TPG tuning Export Pa
Old 06-20-2019, 09:57 AM
Grash73
Grash73's Avatar
2008 G37 coupe MT
timc00k
02-15-2017 09:15 AM
G37sPhoton
10-04-2015 11:08 PM
Landshark
09-29-2015 11:20 PM
Quick Reply: Uprev cooling Fans control
