g37 coupe wont ignite
Old Aug 18, 2012 | 02:54 PM
deminus's Avatar
deminus
hi everyone, i just bought a 08 g37 journey for my project. i wasnt running because of water damage. i changed the BCM and had the key reprogramed. the car cranking, sprayed fuel but didnt ignite. i check the ignigtion coils and the harness, they are fine. so i replaced the ecm( a used ecm) the car still wont ignite, even worst than the original ecm. i think it may be a problem with the different ecm which needs to be reprogram with the car. anyone has experienced this problem before, please help. thanks
Old Aug 18, 2012 | 05:30 PM
Modme's Avatar
Modme
Once you change the bcm or ecm, the key must be reprogrammed.
Old Aug 18, 2012 | 06:35 PM
deminus's Avatar
deminus
thanks man, i reprogram the key after changed the bcm. for now, i put the g37 in the dealer to have them figure it out. hope they will come up with some easy fix like reprogram the system. what do you think about the nissan consult 3 from ebay , is it reliable ? thanks man
Old Aug 18, 2012 | 07:42 PM
Modme's Avatar
Modme
The ebay consult III works but it has a learning curve. You will also need to purchase the security card separately in order to program keys. I do not have the security card, so i cannot attest to how that works.
KJA8686
Mar 15, 2021 01:27 AM
BANNISTER
Dec 10, 2015 04:14 PM
sydnrusty
Nov 21, 2015 10:42 PM
Slateg37
Sep 16, 2015 05:52 PM
pcwd
Aug 12, 2015 06:54 PM
