Help Engine noise
Old Jan 23, 2012 | 10:46 AM
mad_g37's Avatar
mad_g37
Engine noise
Notice this noise after driving for a while. Is it normal sound?
Thanks
G37_01232012 - YouTube
Old Jan 23, 2012 | 07:31 PM
tech7's Avatar
tech7
as odd as it sounds ....yes its normal....there is a solenoid right under the cover on the passenger side...
Old Jan 23, 2012 | 08:08 PM
juicybusa's Avatar
juicybusa
I have to respectfully disagree- not normal
Old Jan 23, 2012 | 08:20 PM
tech7's Avatar
tech7
why do you disagree?
Old Jan 23, 2012 | 09:14 PM
GPR-37s's Avatar
GPR-37s
That doesn't sound right to me and sounds different from what I've heard and experienced personally.... Take it to the dealership....
Old Jan 24, 2012 | 10:01 AM
mad_g37's Avatar
mad_g37
Thanks a lot guys. What might be the cause? so I can advise the tech instead of getting bs.
Old Jan 24, 2012 | 10:17 AM
Rad_Slinger's Avatar
Rad_Slinger
Sounds like rocker arms are a little loud. Doesn't sound terrible though. What's it sound like when it's revved? Noise get louder or go away?
Either way, ya....take it to the shop. What's the worst they can say...there's nothing wrong with it?
Better safe than sorry.
Old Jan 24, 2012 | 11:47 AM
tech7's Avatar
tech7
i got the info on that solenoid straight from the FSM
"The EVAP canister purge volume control solenoid valve is used to control the flow rate of fuel vapor from the EVAP canister. the EVAP canister purge volume control solenoid valve is moved by ON/OFF pulses from the ECM. the longer the ON pulse, the greater the amount of fuel vapor that will flow through the valve."
Old Jan 24, 2012 | 02:00 PM
juicybusa's Avatar
juicybusa
Dont' disagree that the solenoid exits or even how it functions: however the sound the OP posted is not a solenoid. That's either valvetrain noise or an exhaust leak.
Old Jan 24, 2012 | 08:56 PM
mad_g37's Avatar
mad_g37
I can't reproduce the noise when cold start, then rev to 3000 rpm a few times. The noise only happens after driving for a while.
Old Jan 24, 2012 | 09:20 PM
tech7's Avatar
tech7
That Is definitely not valvetrain related..if it was it would happen all the time or when the vehicle reached normal operating temp.
Old Jan 24, 2012 | 10:45 PM
juicybusa's Avatar
juicybusa
Actually valve train noise especially in a vvel motor most definitely CAN be intermittent and or temperature related.
Old Jan 25, 2012 | 07:17 AM
tech7's Avatar
tech7
I've heard the noise that vvel makes numerous times...and the issue the OP has in my opinion is neither vavletrain nor an exhaust leak ...I'm sticking to it being that solenoid pulsing on/off....
Old Jan 25, 2012 | 09:35 AM
juicybusa's Avatar
juicybusa
OK, guess I should get a service appointment and get that normal noise added to my G since it currently doesn't have any sign of that noise at any time under any circumstance- I want everything I'm supposed to have
Old Jan 25, 2012 | 09:46 AM
mad_g37's Avatar
mad_g37
what about noisy fuel injector?
