G37 Sedan Paddle Shifters
Old Nov 15, 2011 | 11:51 PM
  #136
blackhawksfan81's Avatar
blackhawksfan81
Thanks but I called OC Infiniti right after I posted earlier and already ordered them.
Old Nov 17, 2011 | 04:58 PM
  #137
Almatti's Avatar
Almatti
Originally Posted by Hybrid_DET
Yes wheat and stone interior use same part number.
I have one set of wheat/stone covers in stock with graphite paddles if you are interested.
Are the Paddles you are offering for G37X with Premium Package (electric steering wheel mover) - does it matter if you have Navigation too?
I have a Wheat Interior - the steering wheel color is Greyish Brown .
What is the price?
Old Nov 17, 2011 | 04:59 PM
  #138
Tunerz_Store's Avatar
Tunerz_Store
Parts Specialist
pm sent.
Old Nov 26, 2011 | 08:17 PM
  #139
biggigeez's Avatar
biggigeez
Thanks to this forum and OC infiniti... now I got myself some paddle shifters... sweet
Old Nov 28, 2011 | 12:38 AM
  #140
Lowdown's Avatar
Lowdown
Got the shifters....
Installed them in about 45 min. You do need some tools to remove the clips but the job is simple and quick. OEM RULES!!!!
Thanks for the guides and tips guys!!!
Old Nov 28, 2011 | 06:02 PM
  #141
dlu's Avatar
dlu
I installed them a few weeks ago as well. Very thankful for the helpful posts guys!
I thought the removal process was going to be difficult, but it was really easy. It was putting the trim pieces back together that was PAINFUL. I broke a little tab piece.
The rev-matched downshifts are so much fun to hear, still not tired of it yet!!!
Old Nov 28, 2011 | 11:00 PM
  #142
TinsleyC's Avatar
TinsleyC
My car lunges forward slightly when doing a rev-matched downshift - that makes it sort of annoying. Does anyone else experience this? I would prefer a slight pull backward, not a lunge forward...
Old Nov 30, 2011 | 03:13 PM
  #143
Tunerz_Store
Parts Specialist
Mine does it as well especially 3-2 downshift.
Old Nov 30, 2011 | 06:14 PM
  #144
DadsTaxi's Avatar
DadsTaxi
Maybe I'm missing something but isn't that the point of a rev matching, the ECU spins up the engine to match the required RPM that the gear selection is needing. Or am I missing something?
Old Nov 30, 2011 | 06:47 PM
  #145
blackhawksfan81
That makes sense. During the rev match, the transmission is disengaged from the wheels (same as clutch pedal to the floor in a manual).
Old Nov 30, 2011 | 11:15 PM
  #146
TinsleyC's Avatar
TinsleyC
What I feel is a slight acceleration of the car on downshift. I understand the point of rev-matching, it's to speed up the engine to match the new gearing to prevent a sudden drag on the rear wheels which could cause them to break loose, causing loss of control. Still, what I sense in all the lower gears - especially 2-1, is a lunge forward of the vehicle when the engine speeds up and engages the tranny.
So if I've got my foot off the gas and I'm rolling to a stop in 2nd gear (manual mode) and I drop to 1st, I'll feel a brief acceleration as the engine speeds up and engages, then engine braking as the rpm's drop back down - still with foot off the gas.
In a perfect world there would be an rpm increase to rev match but no forward acceleration in the process.
Old Dec 1, 2011 | 11:00 AM
  #147
DadsTaxi's Avatar
DadsTaxi
Gotcha, I guess I've not really felt that when dropping into 1st in manual mode, though I'm normally also on the brakes when this is happening. Maybe that is subduing the surge of acceleration. Will have to try it out on my drive home today.
Old Dec 1, 2011 | 12:13 PM
  #148
thebals's Avatar
thebals
Got them Paddle shifters installed a couple days ago. The install was quite easy. Took me 30 mins. I reused the top trim that was already there. I didn't see the need to replace it.
I find the paddles much more convenient than the shifter for gear changes in DS. Plus a bunos that the pddles work in D mode as well
Thanks all on here and the G35driver DIY post for the tips and tricks!
Old Dec 1, 2011 | 01:48 PM
  #149
rlo's Avatar
rlo
Just installed mine as well. Fun novelty item. Also good to find out and try the downshift while in D mode.
One thing about the install I was not sure about is if the simulated leather fabric piece that hangs from the top trim was suppose to tuck into the plastic coverings or lay on the outside of the trim pieces.
Doesnt really affect anything just curious.
Old Dec 1, 2011 | 02:00 PM
  #150
rpm&my_G35's Avatar
rpm&my_G35
Is it this piece...not sure as I don't have paddles
