shimmering metallic material in oil
Old Jun 26, 2011 | 10:33 PM
LexiG37's Avatar
LexiG37
Unhappy shimmering metallic material in oil
I had an oil change done at the dealer last week. The car has 33,000km (~20,000 mi) on it. Regular maint with dealer stamps in the mainteance book every 6,000 km. They poured in regular 5w30 oil and replaced the filter. I drove on it a couple of days and decided it would be interesting to see if any metallic stuff came out with the initial few drops as I unscrewed the drain plug. To my shock that's exactly what happened. I saw a little bit of barely visible metallic, brass colored particles under very itense light with the initial seepage as I slowly unscrewed the plug. I'm worried.
Someone please tell me it's normal...
btw, I replaced the quart I drained off with Amsoil 5w30. (It says on the bottle you can mix it with ANY oil).
p.s. my car sounds like a rough-running V8 for the first 5-10 seconds on a cold start, then runs like a champ. Is that normal?
Thanks
LexiG37
Old Jun 26, 2011 | 10:38 PM
Doggy's Avatar
Doggy
So you knew that there was metallic stuff in the oil? I'm not sure the way it's worded, but I don't think that's normal.
Old Jun 26, 2011 | 10:51 PM
JohnEnglish's Avatar
JohnEnglish
A very fine metallic dust is normal, metal shavings are not. Sounds like you're seeing a very fine dust. You would easily notice shavings if there were any.
I wouldn't worry about it.
Old Jun 26, 2011 | 11:57 PM
LexiG37's Avatar
LexiG37
I didn't know about the metallic stuff. I wasn't expecting it either. Someone at work told me they found it their oil, so I wanted to see if my engine is OK...
Old Jun 26, 2011 | 11:59 PM
LexiG37's Avatar
LexiG37
Yeah, dust is a good description of what I saw. Anyways, I have lots of warranty left and I will only let Infiniti work on my car just in case this thing decides to eat its bearings...
Old Jun 27, 2011 | 12:43 AM
pricojorge's Avatar
pricojorge
drain your oil and use a magnet to see exactly how much metal you see then go from there.
you can clean up the metal and pour that oil back in if you want.
Old Jun 27, 2011 | 01:50 AM
gee wiz's Avatar
gee wiz
As for the rougher idling for a few seconds at cold start, that's normal.
Old Jun 27, 2011 | 02:55 PM
LexiG37's Avatar
LexiG37
Phew, that's a relief!
Old Jun 27, 2011 | 06:41 PM
Boomer-Bob's Avatar
Boomer-Bob
I don't know about G's. But, I used to see the sort of thing you mentioned in oil often. It would show especially when some old oil is swirled in fresh, clear oil, in sunlight.
If you are really paranoid, you can change oil filters and cut the old one open to take a look. But IMHO, I think you are okay.
Old Jun 27, 2011 | 09:49 PM
LexiG37's Avatar
LexiG37
I am a bit paranoid. I think I'll take your advice and spin a new Nissan filter on, and dismember the old one for investigative purposes. I'll report back on my findings in a few days.
Old Jun 27, 2011 | 11:18 PM
pricojorge's Avatar
pricojorge
ya my car when cold start goes to about 1.6k rpms and starts to go down as it gets warmer, or i shift into first
Old Jun 27, 2011 | 11:25 PM
LexiG37's Avatar
LexiG37
Mine too goes to 1600 rpm at first and that's pretty normal. But does yours sound rough for the first few secs?
Old Jun 27, 2011 | 11:37 PM
dkmura's Avatar
dkmura
20 Year Member
If you're really interested in how much contamination you have, you could get a full used oil analysis (UOA). Catch a small sample during an oil change and send it off to allow the lab to do a full analysis. It's the only way to get a quantitative breakdown of what is going on inside your VQ37VHR.
Old Jun 27, 2011 | 11:47 PM
LexiG37's Avatar
LexiG37
Agreed. Blackstone comes to mind. Now that the postal strike in Canada is history (with the help of our gov't) I can send a sample in. My bro(industrial/mechanical engineer) can help me decipher the results.
Old Jun 28, 2011 | 09:40 AM
XsG's Avatar
XsG
An almost diesel engine sound seems to be normal for these cars on cold startup. Mine last for about 40 seconds before getting smooth and quiet. When I went in to complain at the dealership, they let me start up a couple of new Gs on the lot and they had the noise too. Oddly enough, it only happens in warm weather. In the winter, the car is much quieter on startup.
