what mph range should i be in?
Old Jun 25, 2011 | 08:23 PM
chogrilla's Avatar
chogrilla
im trying to use ds mode in my car more often these days but im lost on what gear i should be in for my speed range. afraid ill damage the engine/transmission faster if i dont do it right. anyone have a reference for what mph i should be in for each gear? looked at the car manual but im not sure if the reference there is for ds mode or for cars with manual transmission.
Old Jun 25, 2011 | 08:27 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
just look at your tachometer/ speedometer....
Rev it up and figure it out
Otherwise check the manual. Its in there.
Old Jun 25, 2011 | 11:43 PM
OB G's Avatar
OB G
Drive it in auto. Listen and feel for when the gears change. Take note of where your tach/speedometer is at each upshift. Shift it over to DS. Mimic.
Or shift every ~10-15 mph.
Or just wait until it sounds like your engine is about to explode. Then for sure you should be able to tell when to shift eh?
Old Jun 25, 2011 | 11:46 PM
1NEETO's Avatar
1NEETO
Dude it's an automatic. There's no science behind driving one on manual mode.
But since you seem totally clueless about driving an automatic of all things, here's a quick guide:
Normal driving shift at around 2500-3000 rpm's for good fuel economy. For some power rev it up to 5500 or so. For maximum power redline the thing.
Old Jun 26, 2011 | 12:01 AM
hechen507's Avatar
hechen507
Or spam upshift lol, I think from 1-4 gear it will allow you to shift at 2k rpm and 5-6 you can shift at ~1500rpm
Old Jun 26, 2011 | 12:26 AM
mystakin's Avatar
mystakin
i think our car has max hp at a really high rpm (idk why, but 7200 is coming to mind) so im thinking the longer you stay around there, the best power you'll get. shift at low rpms for good gas mileage.
for ds mode, just use common sense. i think the car wont let you drop it too low if youre good fast. like if youre going 40mph it wont let you drop it to first. so that alone is a protector for your engine. just gauge it yourself, it wont do you much good putting it down to second at 50mph if your rpms are at redline. if you put it into drive sport it normally will down shift you till youre around 3-4k rpms which is where you want to be.
Old Jun 26, 2011 | 06:04 PM
prankiRL's Avatar
prankiRL
Actually It wil llet you drop it into 1st if your around 35-40 mph. Its been done to me before
Old Jun 26, 2011 | 07:19 PM
Soliditude's Avatar
Soliditude
Well, I'd say that there's no use driving the car in DS unless you're planning to redline the thing or give it some hard acceleration. That's the entire purpose of DS, really: To downshift/upshift when you want to give it a good run. DS also makes your car work at slightly elevated RPMs even in the same gear than you'd normally be in, so it's useless for regular driving, if that's what you're referring to. If you want to drive it like a manual, it won't work; you'd need a manual for that.
Old Jun 26, 2011 | 07:37 PM
trcb777's Avatar
trcb777
I'm Confused. Are you guys talking about manual mode? I thought DS is just a more aggressive D mode.
Old Jun 26, 2011 | 07:40 PM
ShyAznB8oi's Avatar
ShyAznB8oi
Yeah he's right.. DS is just more aggressive of the D Mode..
When you're on DS, and downshift.. It will say "1" = 1st gear, now it becomes trip tronics.
I always shift every 3k on each gear, or more depending how much speed I need to do.
r0cketm0nkey
General Tech Questions
17
Nov 23, 2015 03:34 AM
G37sPhoton
Oct 4, 2015 11:08 PM
Bennyjoel
Sep 30, 2015 11:56 PM
MrRiv
Sep 29, 2015 04:59 PM
czirrfb
Sep 16, 2015 04:09 PM
