Oil color is dark
Old Jun 21, 2011 | 11:40 PM
davelim's Avatar
davelim
Oil color is dark
Hi,
My ride: 2011 g37s 6mt sedan
Question: I have a bit under 3K miles on the car. I checked the oil dipstick and noticed it was more than half empty and the color was a very dirty dark color. Should the oil be light colored when it's clean and dark brown colored when it is dirty and in need of an oil change? Thanks in advance to helpful responses.
Old Jun 22, 2011 | 12:01 AM
Neal376's Avatar
Neal376
Originally Posted by davelim
Hi,
oil color has no correlation with cleanliness. it turns black after a week or so.
dipstick only measures the top quart of your oil pan
Old Jun 22, 2011 | 12:03 AM
Wongster's Avatar
Wongster
Oil color doesn't tell you if your oil is good or bad. I'd be more concerned that it was more than half empty.
Old Jun 22, 2011 | 12:06 AM
eksigned's Avatar
eksigned
For reinforcement. The color of the oil is NOT an indication of how "well" the oil is doing. If you're interested in how long, between intervals, you can stretch your motor oil for, try a UOA (used oil analysis).
Old Jun 22, 2011 | 04:30 AM
6mtg37s's Avatar
6mtg37s
Id say just change it at 3k to be sure. You should always do the first change a little sooner since the engine is new and jist breaking in.
Old Jun 22, 2011 | 08:32 AM
Chris11LE's Avatar
Chris11LE
Like everyone said, the color isnt a huge indicator of much of anything. At 1200 miles the dipstick on my car came out perfectly clean, but I changed the oil shortly after and what was coming out of the pan sure was dirty
I would be more worried about why you were missing 1/2 quart of oil (the space between the 2 dots on the dipstick represent 1 full quart)
Old Jun 22, 2011 | 10:35 AM
NeverBoneStock's Avatar
NeverBoneStock
Time for a oil consumption test...
Old Jun 22, 2011 | 05:28 PM
4DOORFUN's Avatar
4DOORFUN
My G consumed oil during break in. This is normal. Pretty sure it even says that in the owner's manual.
Old Jun 22, 2011 | 05:50 PM
Chris11LE's Avatar
Chris11LE
I thought mine was too, rechecked the oil another two times and it came out fine. For some reason it seems really easy to catch the dipstick on something on the way out, smearing the oil and not showing the true level.
The oil consumption test (that applies to years other than 2011 I think) shows the acceptable consumption range based on miles on the engine. There is no oil consumption TSB for the 2011s (the OP has a 2011), so I dont know if it still applies or not.
Old Jun 23, 2011 | 10:51 PM
Bo2point0's Avatar
Bo2point0
Engine oil color is a result of 2 things.
Thermal break down and/or suspended particles in the fluid.
Compare the consistency/viscosity of the fluid with new oil.
Also, when did you check the oil. Right after you drove or when the engine was cold.
if right after you drove, the oil will read much lower than on a cold engine.
eljoker
Future Models
19
May 30, 2022 11:48 AM
Wreckreation
Sep 21, 2015 06:27 PM
cvg37s
Sep 12, 2015 07:17 PM
Amrit.bhathal
Sep 11, 2015 07:36 PM
