LSD on a G37x
This feel off, I was thinking of doing the 4.08 swap on mine, but how will the Tcase act? Anyone know, we all know that the tcase locks up if the rears slip? Has anyone done it ?
Thanx man that thing looks to small to have a gear change LOL
You might be able to swap for 3.69 gears from the 07-08 G35x. Not sure how drastic the change is but should still be a noticeable since its a 10% higher ratio.
The entire carrier assembly should be direct bolt on judging from pictures and also the parts compatible across all the V36. You just might be the first 37x to do so.
I found a front differential from an 08 g35x for $200 on eBay. I want to do the switch but I really don't want to be the guinea pig for this one.
And not to bomb the thread but to answer the OPs question yes an LSD on theX is a achievable. And it's been done along with the arguing as why or why not to do it. Check it out.
https://www.myg37.com/forums/engine-drivetrain-and-forced-induction/260522-vlsd-on-awd-g.html
This is what I've been trying to find out. I heard the rear differential bolts up directly from an 08 g35. However I'm not sure about the front and I've yet to get a definitive answer as no one seems to have done this on the X.
Go to pg 118
http://www.nicoclub.com/FSM/G35/Sedan/2008/DLN.pdf
Go to pg 128
http://www.nicoclub.com/FSM/G37/Sedan/2011/DLN.pdf
