Review Nismo Radiator Caps
Old Feb 8, 2011 | 02:20 PM
surfjax87's Avatar
surfjax87
Originally Posted by JustNgo
Unless I my understanding of safety factor is incorrect, 20% would put you at .15 MPa, not 1.5 MPa, which is about 1.5 atm if I remember my units conversions correctly, so if the pressure in the radiator is 1 atm gauge, then we are totally screwed.
Safety factor is an extra margin that manufacturers put into their designs to prevent problems near the maximum ratings of products. Basically the manufacturer doesn't want a failure at 1.300001 MPa, so they make sure that the maximum pressure the cap sustain is greater than the rated pressure on the top of the cap. So a 20% safety factor means the cap can withstand a sustained pressure 20% above the rated pressure on the cap. This adds .26 MPa in this example, so the total pressure the cap can withstand would be a little above 1.5 MPa.
Sorry about any confusion there and for nerding up the thread, but as an engineer, I have a pretty good familiarity with this kind of stuff.
Old Feb 8, 2011 | 03:15 PM
JustNgo's Avatar
JustNgo
I'm afraid you may have misread the specifications of the caps. The caps are rated at .13 MPa, not 1.3 MPa, which is the only way for you to get those numbers. Once again, this leads to .15 MPa, with a 20% safety factor, which is about 1.5 atm.
Old Feb 8, 2011 | 06:24 PM
surfjax87's Avatar
surfjax87
Oh, good call. Looks like I missed that . So I guess we're still at the same point of whether .13 MPa is enough when the cap in our G's is .137 MPa.
Old Feb 8, 2011 | 06:56 PM
JustNgo's Avatar
JustNgo
It shouldn't be a big deal, it may even be that the Nismo cap is .137 MPa but didn't write it out to enough decimal places, but yeah, your earlier findings of 2 atm are a bit high for these caps...
Old Feb 8, 2011 | 07:01 PM
Kidcane's Avatar
Kidcane
Florida G Club
LOL you guys take radiator cap science pretty serious huh?
My thought process, "Oh look a cool Nismo cap! Its only $10! But really who is going to see it? IDK I am getting it anyway." purchased and installed.
Old Feb 8, 2011 | 11:05 PM
JustNgo's Avatar
JustNgo
Lol I'm a mechanical engineering student so I was curious to see how he got his numbers.
Old Feb 9, 2011 | 01:08 AM
surfjax87's Avatar
surfjax87
Kidcane, you have no idea, lol.
I guess this proved that my engineering degree doesn't guarantee the ability to read.
beng37s
Dec 8, 2019 01:21 PM
faze2988
Oct 7, 2015 12:05 AM
