Help Tranny Issues
Tranny Issues
So I have a 08 G37 . Its been really reliable minus a few issues . The biggest one is the tranny . I had this god awful rattle coming from my original tranny when I was stopped in traffic. I had a new tranny put in it about 9 mnths ago and dame issue .. Any suggestions ???? Thanx !
*edit*
Found this thread doing a quick search. It is most likely a bad input shaft bearing. Are you certain that the dealer installed a new transmission?
https://www.myg37.com/forums/g37-cou...n-neutral.html
Hmmm, could be even more serious than a TOB. When the TOB is bad they make noise when you press down the clutch pedal, not the other way around. Go to the dealer and complain again, a transmission that makes noise when it's spinning is NOT normal. I'm now thinking input shaft bearing considering I have seen this on other cars/trucks before but you say you have a new transmission. Whatever the case may be I would bring it back to the dealer ASAP.
*edit*
*edit*
If they have replaced it before make them replcae it again. Tell them its not acceptable and needs to be fixed. With that kind of attitude im sure they will take care of you. Given this being the 2nd time you had this problem and the first time they replaced it so obviously they know its not normal and the problem should be fixed. just my 2 cents.
I know that I may risk negative experience points on this, but I can't resist... Where I lived for quite a long time recently (Thailand) having tranny issues was a completely different problem.
To get back on topic, I hope that you can resolve this and report back to us so that we can learn.
Thanks!
Thanks!
I knew quite a few of them, but luckily never had any "encounters" with one...there was one time that my boss mentioned that he knew this great strip bar. We walked in and noted how friendly they were. Trust me when I say that we had no transmission issues while exiting bar in 6th gear.
