Problem with Manual shift mode for AT
Old Dec 19, 2010 | 04:59 AM
G-Rider-Azn's Avatar
G-Rider-Azn
I 've been using manual shift mode (DS) on my 08 S coupe with Automatic Transmission. I had no problem using DS for years and recently, when i rev high in manual shift mode it changes into Automatic mode (D) itself with the gear shift put in DS mode. Anyone else had this problem? I was racing against 350Z and i got owned as the gear changed from 2nd to 3rd without me actually shifting it into 3rd gear (i was using manual shift mode) and seems like this problem is persistent as it happened every time i used DS mode since then.
Old Dec 19, 2010 | 09:46 AM
RISKY GUY's Avatar
RISKY GUY
you have a bad selenoid in your shifter.
it's an easy fix, car / trans.must be hot for you to duplicate it.
if the dealer checks when the car is cold,it won't happen.
make sure you take a tech for a ride when she's fully warmed up. There is alot of 08 autos have had this exact problem.
ill12will8
Oct 26, 2015 10:09 PM
claudiohv
Sep 17, 2015 01:43 AM
pcwd
Sep 15, 2015 10:06 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
ZachThomas
Sep 3, 2015 01:40 PM
