About Gas : 87 or 91 or 93
Old Oct 5, 2010 | 12:45 AM
terfer's Avatar
terfer
The manual says 91+ so i usually put whatevers available.
Old Oct 5, 2010 | 01:06 AM
eksigned's Avatar
eksigned
Yeah, 91 or 93 doesn't really matter. If my memory serves me correctly, the purpose of higher octane level gases, aside from the fact that the factory engines are tuned with this level of octane in mind, is to prevent engine ping. Every notice more chatter or pinging in from your engine when you use 87 octane? Knock sensors are retarding combustion to deal with the lower octane level. Octane levels above 91 promote advanced timing...in theory? Don't quote me on this though...
Can anyone chime in?
Old Oct 5, 2010 | 06:53 AM
AvosG37's Avatar
AvosG37
I just stay with 76 gas station wit 91. cheapest and closest gas station to my home. one day, i accidently filled wit 87 n i felt different from 91. i felt 87 little bit slower n quicker ran out of gas.
Old Oct 5, 2010 | 07:29 PM
xBLACKMAM8Ax's Avatar
xBLACKMAM8Ax
I prefer to only use Shell V-Power but i every now and then i'll use a different brand so that my car doesn't get used just one type of gas. I will NOT use BP gas though.
Old Oct 5, 2010 | 07:52 PM
AvosG37's Avatar
AvosG37
wat is different 76 gas station n shell wit 91 gas??
Old Oct 5, 2010 | 08:08 PM
Adam West's Avatar
Adam West
Exxon Mobil 93 here in MD. I loved Sunoco 93 up in NY, but they dont have those stations around here. As for octane rules, you should put the closest to what the manufacturer recommends for best performance, anything beyond their recommended octane level isn't going to buy you too much unless the car is specifically tuned to take advantage of it. I can't get 91 here in MD, so 93 it is.
The higher the octane means more knock/detonation resistance in high performance applications (high compression), it does not necessarily mean more power. 87 octane will actually produce more power (burns faster/hotter) than 93 octane (burns slower/cooler) in an application designed to use it. Thats why putting in higher octane fuel like 91 or 93 in a car that requires 87 isn't yielding any additional performance, you may even be giving up some efficiency. This is why the manufacturer always recommends and tunes engines according to the octane they require. You always need to blend detonation resistance with BTU output for maximum efficiency.
Old Oct 5, 2010 | 09:15 PM
redfoster's Avatar
redfoster
Adam West pretty much nailed it. Lower octanes will burn hotter than the engine is designed for. Do our cars ping like older cars with lower octane?? Not really. Reason being is that we have variable valve VQ motors and our computers are constantly compensating.
Just because you don't hear a ping doesn't necessarily mean everything is alright. In the short term you might only notice the fuel mileage change. But the long term stress on the engine is not good and for this reason you should burn the recommended octane, or as close as you can.
Like some of the other posters I find the best fuel mileage using Shell V-Power. I am disappointed with fuel stations promoting the use of "cleaner" higher octane fuels for their customers. Only about 5% of cars are designed/tuned to run on high octane premium gas. Most cars have no benefit, maybe even lose efficiency running something higher than they are designed for. Sigh.
Old Oct 5, 2010 | 11:13 PM
ozzypriest's Avatar
ozzypriest
If you are using 87 and your engine is pinging, you could be doing mucho damage to your vehicle. It is no laughing matter.
ping definition:
Knocking (also called knock, detonation, spark knock, pinging or pinking) in spark-ignition internal combustion engines occurs when combustion of the air/fuel mixture in the cylinder starts off correctly in response to ignition by the spark plug, but one or more pockets of air/fuel mixture explode outside the envelope of the normal combustion front. The fuel-air charge is meant to be ignited by the spark plug only, and at a precise time in the piston's stroke cycle. The peak of the combustion process no longer occurs at the optimum moment for the four-stroke cycle. The shock wave creates the characteristic metallic "pinging" sound, and cylinder pressure increases dramatically. Effects of engine knocking range from inconsequential to completely destructive.
And then the effects of abnormal combustion:
If detonation is allowed to persist under extreme conditions or over many engine cycles, engine parts can be damaged or destroyed. The simplest deleterious effects are typically particle wear caused by moderate knocking, which may further ensue through the engine's oil system and cause wear on other parts before being trapped by the oil filter. Severe knocking can lead to catastrophic failure in the form of physical holes punched through the piston or head (i.e., rupture of the combustion chamber), either of which depressurizes the affected cylinder and introduces large metal fragments, fuel, and combustion products into the oil system. Hypereutectic pistons are known to break easily from such shock waves.
source: Engine knocking - Wikipedia, the free encyclopedia
I've always used 93 from Sam's club, but I think I'll go down to 91. I had a tune that required 93 for a while, but it is gone now, so why waste the money, I guess.
Old Oct 6, 2010 | 12:23 AM
dainjarouz's Avatar
dainjarouz
would higher octane...say 97 yield more HP or just a waste of money?
Old Oct 6, 2010 | 12:39 AM
PureNick's Avatar
PureNick
The stock ECU works at peak performance at around 91 octane.
The car will run on lower grades but treats it like any cheap, crappy gas you decide to dump in it: it pulls timing from the upper ranges (5,300ish RPMs in this engine) to prevent detonation. The highly adaptable ECU's in modern cars are what allow oil companies to sell us on this 91 crap in the first place.
Anything over ~94 octane is probably a waste, since, at least as far I've seen documented, the ECU isn't optimized for it.
Now, if you're talking to EVO/STi guys... you sure as hell can tell the difference between 91 and 93. I should know, I used to own one.
Old Oct 15, 2010 | 03:18 AM
maxfinity's Avatar
maxfinity
I live in Miami and the only octane levels available are 87, 89, and 93. I've used only Chevron 93 since i bought the car. Since you guys are saying u get better gas mileage on Shell v power im going to give them a shot. I would NEVER use any gas other than 93... but i have put 87 in a loaner before. Did seem to have a rough idle afterwards.
Old Oct 15, 2010 | 09:25 AM
NyC_G37x's Avatar
NyC_G37x
my g only uses 93 here in new york.
Old Oct 15, 2010 | 01:11 PM
jude26's Avatar
jude26
I always put 93 in my cars, but when I bought my G last week, the dealer said that the reason oil changes are more expensive at the dealer is because they use a special synthetic blend oil that makes it that you can run the car on 87 octane without issue.
Old Oct 15, 2010 | 02:08 PM
  #29
madmax2k1's Avatar
madmax2k1
wow ... total nonsense
Old Oct 15, 2010 | 03:16 PM
  #30
evilpanda's Avatar
evilpanda
i only use 91 and that's the highest octane besides 100 here in SoCal.
