Help 7AT Dyno
Even if your 5th gear is at 1:1, your rear end isn't.
Remember, dyno's are a comparison/tuning tool not a measuring tool. Just don't dyno in 1st where theres so much wheel spin, and don't dyno in high gears so you don't end up doing 200mph with no oncoming air cooling the tires. Anything in between should be fine.
Hey. In 5th gear i was hitting 150. Look in the vert forum. I posted a dyno there. 5th gear we are going to run into a problem with fuel cut off / speed limiter of some sort. 4th gear is probably going to be best. I did a run in 3rd ,4th, and 5th gear.
misc
29
May 24, 2023 03:57 PM
