Help engine not starting!!!
i didnt take my car to the maintenance, i'm 2500km over the maintenance alert...
i was driving at the speed of 180 km and all of a sudden the engine shut down and car stopped!!
checked the engine there was no oil! so i had to fill it up.. so did that!
started the engine,,, and the car wont respond! so i disconnected the battery and kept it for 15 minutes reconnected it and nothing changed!
few minutes later the battery was dead! so i had jump started it but no use!!!
anyone can help!!!!!!!!!!!!!!!???????????
not stock
stillen gen 3
FI test pipes
invidia exhaust
but i had no problems with oil.. its was a little missing only!!
i think its the fuel pump cause its not pumping anything!!!
stillen gen 3
FI test pipes
invidia exhaust
What do you mean "a little bit of oil"? If you run your car with no oil or too little oil it can not lubricate and your motor will be done.
How did the car respond right before the motor stopped?
OH gee. I thought you said no oil in your first post. You can check fuel pressure easily by putting on a fuel pressure guage inline with your fuel hose. Or check to see if the fuse is blown.
