Oil cooler
Old Aug 18, 2010 | 07:52 AM
Breitling65's Avatar
Breitling65
Oil cooler
I read in latest Road & Track that they suggesting installing oil cooler for VQ37 engine if your driving style is aggressive. Anybody got one installed what would you suggest and how much is it?
Old Aug 18, 2010 | 07:59 AM
bschurr's Avatar
bschurr
So, I recently spent a day with my G Vert on the track & I couldnt agree more! An oil cooler would do wonderous things for our cars under the right circumstances.
That being said, please do your homework because the oil cooler debate is as old as the chicken and egg issue. Some are dead set against oil coolers because they do not allow the oil to reach ideal operating temperature and can therefore cause mare harm than good.
If driven aggressively on the street there is no NEED for an oil cooler - if you want to track your G then you absolutely NEED and oil cooler. Just my $0.02.
Flame suit on - bring it!
Old Aug 18, 2010 | 09:31 AM
Weiboy718's Avatar
Weiboy718
https://www.myg37.com/forums/engine-...installed.html
Old Aug 18, 2010 | 10:03 AM
DmfG37sTT's Avatar
DmfG37sTT
The VQ37VHR is very prone to suffer from high engine oil temps during any sort of extended high speed driving such as motorsports events, and even non competition events such as track days and Autocrosses. The engine can also suffer from high oil temps even with short burst of full throttle use such as on an engine dyno, drag racing and even bumper to bumper traffic. So my two cents would be that it would be a good idea to throw a oil cooler on the car no matter what for better operating temps. no matter what kind of driving you are doing.
Old Aug 18, 2010 | 10:09 AM
Weiboy718's Avatar
Weiboy718
Old Aug 18, 2010 | 10:17 AM
DmfG37sTT's Avatar
DmfG37sTT
I think I just put out your fire.
Old Aug 18, 2010 | 10:44 AM
Presto's Avatar
Presto
stillen or gtm oil cooler? any other options?
Old Aug 18, 2010 | 10:59 AM
g37mobbin's Avatar
g37mobbin
dpends on the size you are looking for and what your future mods are if you consider F/I down the road...but if you want to simply start. You can do the small one from either company. GTM did have an issue with the hoses to begin with but that is over with. You can also DIY oil cooler found on the370z.com
Old Aug 18, 2010 | 11:12 AM
Breitling65
What would be symptoms of overheated oil, should some engine sensor detect it and flash? Will synthetic oil help in this case somehow? Would installing aftermarket oil cooler void warranties? In Road & Track they mentioned some Nissan part for it, why not use one made by Nissan?
Old Aug 18, 2010 | 11:43 AM
DmfG37sTT's Avatar
DmfG37sTT
Well first off the easiest way to tell if your car is running hot is by looking at the gauge infiniti gives you. You might also tell by knowing your car. if it feels slugish or not running how it normally does its probably not running at right temps. Now for your warrenty question I dont see why infiniti would void it for helping maintain propor oil temps. unless they figure the only reason you have it is to track race and what not.
Old Aug 18, 2010 | 11:44 AM
Calgarywinger's Avatar
Calgarywinger
Do you think this could cause excessive oil consumption? I drive fairly agressively and use Ester.
Old Aug 18, 2010 | 11:49 AM
DmfG37sTT's Avatar
DmfG37sTT
Oil consumption is cause by burning oil. where else would it go??? and if your driving very agrresive and see loose of oil I would for sure go with a oil cooler and see how that helps out. If not I would take it to the dealership asap
Old Aug 18, 2010 | 06:47 PM
Breitling65
Well first off the easiest way to tell if your car is running hot is by looking at the gauge infiniti gives you. .
what exactly gauge it would be?
Old Aug 18, 2010 | 06:48 PM
Breitling65
oil burning? are you sure not bad pistons rings?
Old Aug 18, 2010 | 08:01 PM
Weiboy718's Avatar
Weiboy718
there is no oil temperature gauge for our cars. only thing that's on your dash is you your water/coolant guage. you'll know for sure when your engine is way too hot cuz your ecu will throw you into limp mode.
i would recommend a 25 row oil cooler if you do some tracking. 19 row will be good enough to run it hard once in a while. idk if you're willing to fork out 700-800 for the Nissan oil cooler when you can get a cheaper kit that works the same for a lot less lol. installing a oil cooler will not void warranty unless your dealership are ******. good luck with it!
