My G Coupe RPM =(.
Old Jul 19, 2010 | 05:31 AM
Ahmed Almarzooq's Avatar
Ahmed Almarzooq
My G Coupe RPM =(.
Hellow Everybody,
i think i"m facing a serious problmen !!!
My car rpm starting to be crazy...
since i accelerate then stop accelerate RPM Stuck and going up and down above the 1000x rpm...its not normal ratios in the rpm !!!
the rpm is moving by it self !!!
sometimes i feel the car do the accelrate by it self !!! i dont know why...i got bored from this issue!!! i dont know what to do...
also sometimes i feel the car shifting to the second gear by it self !!!
actually one day i went to normal shop and fill the GAS !!! the Gas of the A\C because one day i felt the Gas is less so
After that the problem has began !!! so mayeb its from the GAS ????
I dont know
Imagine the infiniti they said we are fixing it...but the only reset the RPM...and still its the same problem !! they dont know whats the problem...
anyone faced this problem !?!?!
wish to help me...
thanks.. gambling http://kazinomons.com/
Old Jul 19, 2010 | 05:34 AM
stevelam's Avatar
stevelam
is it still under warranty?
Old Jul 19, 2010 | 05:35 AM
Ahmed Almarzooq
No...its Not under warranty...
Old Jul 19, 2010 | 05:37 AM
G37Sam's Avatar
G37Sam
You need to take it to the dealership immediately man
Old Jul 19, 2010 | 05:41 AM
Ahmed Almarzooq
i took the car to the dealership !!! but they didnt do anything...
they were saying WE CLEAN THE RPM AND RESET IT!! now the car has been fixed !!
after that i took the car for test drive !!! nd still the same problem , i told the u didnt do anything !!!!!...
They said its normal thing... they were escaping from me !!! because they dont know how to fix this problem...in kingdom of bahrain !!! the dealership r sucks !! they dont know anything about INFINITI !! they only knows abt SUNNY TIIDA and so on...
i really dont know what to do !!!
Old Jul 19, 2010 | 05:50 AM
6mtg37s's Avatar
6mtg37s
Reset your ECU, might help.
Old Jul 19, 2010 | 07:36 AM
Ahmed Almarzooq
How Can i Reset ECU !?!
Old Jul 19, 2010 | 07:43 AM
G37Sam's Avatar
G37Sam
Disconnect your battery for a few hours
OR
Here is a quick way to reset your ECU. It is also known to clear codes thrown, and turn off the "Service Engine Soon" Light. It's a little tricky, but works.
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following two procedures quickly five times within 5 seconds:
1. Fully depress the accelerator pedal (HARD).
2. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
After the car is "on" (engine not started), I waited 2 seconds then floored it 5 times in 4 seconds. Everyelse was the same.
Old Jul 19, 2010 | 07:52 AM
Ahmed Almarzooq
Thank You Sam...but i dont think so this gonna fix my RPM Problem !!!
Old Jul 19, 2010 | 07:55 AM
G37Sam's Avatar
G37Sam
Give it a shot you got nothing to lose
Old Jul 19, 2010 | 01:22 PM
majin ssj eric's Avatar
majin ssj eric
I can't really understand what you are saying because of the language barrier. It would help if you could make a video of what the actual problem is...
Old Jul 19, 2010 | 10:08 PM
Frankyg37s's Avatar
Frankyg37s
what year is the car im guessing an 08 and is it a 7 or 5at ???
Old Jul 19, 2010 | 10:31 PM
Greg Lecewicz's Avatar
Greg Lecewicz
Oh, yeah. I once knew Sunny Tiida, she was a girl of loose manners and the lips sweeter than a finest baklava...
Old Jul 20, 2010 | 12:48 AM
Ahmed Almarzooq
My Car is 2008 5AT
i will try to upload a video after couple days...
thank u all ...
Old Jul 20, 2010 | 09:15 AM
YetiNole's Avatar
YetiNole
I had what I think you're describing on my Mazda back in the day. The RPMs would jump up and down while idling. Took it to the shop a bunch of times without luck. Then a friend randomly was able to diagnose a leak in the air intake. That fixed it.
